Part of headlight staying on
I know this is an old thread but I recently bought a First Edition. I noticed the DRLs stay lit long after the lights went out (set to 120 seconds).
After seeing this post it set the delay to 20 seconds and everything turned off as it should. It seems my issue is on the longer delay. I have 6 weeks remaining on the basic warranty so I'm debating if I should bother having it looked at.
Are you stating that setting the delay to 20 seconds the lights turn off at 20 seconds but setting the delay to 120 seconds the lights will not turn off even after much longer than 120 seconds?
if it’s that easy to replicate you can show the dealership but if intermittent it might be difficult for the dealership to diagnose the issue.
Correy
Correy
Connecticut
The lights go out at 120 seconds but the DRLs stay on. At 20 second delay, everything goes off as it should
Be sure that all doors including rear hatch are fully closed (others reported a door left open and DRLs stay on).
and are the DRLs staying on more than 10 minutes? (when you have the headlamp 120 second timeout selected)
and if it is repeatable you can have the dealership diagnose.
btw here is another post ..
https://www.broncosportforum.com/forum/threads/daytime-running-lights-sometimes-stay-on-after-shutdown.4418/
Deleted member 12075
Same issue. Doors are closed/locked, changed the values in settings, they still remain on 8-10 minutes:mad::mad::mad:
SHocking
Scott
Detroit
Been dealing with this for a year. Randomly decides to keep the running headlights on. So I have to unlock and then re-lock it again to get them to go off. I'm used to double checking to see if the running headlights are off EVERY time I leave the car. Dealer "could not replicate" the issue so didn't fix the issue. No big deal really, just a pain to have to always check on this quirk instead of locking and leaving your car like any other car I've ever had, ha
”most” people who post about the lights staying on for ‘21-‘23 models have had the headlamp module replaced which solved the excessive time lights remain on
I think the part is relatively cheap and seems to have been redesigned to correct the issue
There is a TSB or SSM on the issue but I can’t recall what it is. The only similar SSM I have is this one (not saying is applicable to your post it’s just one I recall):
SSM 51645 ZUZ1-ZUZZ Bronco
Sport - Low Beams Turn On By Themselves While The Vehicle Is Off For 10 Or More Minutes - DTC B1533
The headlamp module applies to this instrument panel switch and is often difficult for a dealership to diagnose as the problem (because owners have reported the issue cannot be replicated every time):
Ford Bronco Sport Part of headlight staying on IMG_0835
Speaking as a software guy, I would try changing the timeout for the lights to a new value. You can always change it back, I just worry that it was never set and may be picking up random values.
It's not a time-out issue, I think it has something to do with the switch its self. I have the same issue and have run the gamut of free things to do. I was hoping someone else with the same issue tried swapping out the switch b4 I pony-up$80 or so bucks
been there, done that, no resolve
Can you please be more specific to explain what you mean by “ been there, done that, no resolve “?
For example, in my earlier post where owners replaced the headlamp module (which solved the issue of their lights remaining on past 10 minutes), did you as well have the headlamp module replaced?
Or were you referring to something else you tried but did not resolve the issue?
I have the delay set to off and it still does it
Me3
Paul
Northern Nevada
RAV4
How do you guys lock your door? When I first got the car I used the fob to lock up and they stayed on sometimes like you mention. It stopped after a few weeks, I thought on it’s own. Thinking back now I had started to use the lock button on the inside door panel usually , or the touch sensor on the outside door handle, and the running lights stay on about 15 seconds after the headlights turn off. I never use the fob anymore.
doesn't seem to matter if I lock it or not, hit the lock button once or twice, or use the fob once or twice, the issue remains
Cursed Bronco
Dakota
Indianapolis, IN
If you wait until the lights turn off themselves, then lock the vehicle it will work. I have been dealing with this for years, even after having the "fix" done. Alternatively, you can lock the car with the fob, then unlock it to flash the DRLs, then lock it back and they will stay off.
