Pssst. Hey missing BS parts. Imma comin fo ya!
Get the Ottocast Air-2 Pro adapter for wireless. Carplay That unit is blistering fast, almost instant.
Still wired, though.
Cursed Bronco
Dakota
Indianapolis, IN
illuminated cup holders - You buy the illuminated cup holders for a Ford Escape. The newer models are not wired for them. You wire them in under the dash with the ambient light there (if equipped). Plenty of info in this forum if interested.
Tow Hook - My BS is a OBX model. Not equipped with tow hooks per say. The rear bumper has a small panel that pops out. You can buy a tow hook from
Ford that will screw in there if needed.
Do you really have to buy the escape cup holders? I saw a post about a guy just swapping out the console for a unit from an OBX?
Sojourner
Maryland
Mrmike
Syracuse, New York 13219
Not all years or models have the illuminated ones. Make sure they are illuminated. The same goes for the factory wiring. For my '23 OBX I had to tap in under the dash into the ambient wiring.
Oso Fell
Oso
NYC
23 Bronco Sport
If you look up under the passenger side dash, there is a wide open space between the dash and the firewall (if you don't have it). That "insulator" is a cover that covers that space. It just clips in. Cheers!
You could do what I did and order k2gz6a949b. It's the exact cover for the 2.0l but Lincoln badged. I took off the Lincoln badge and popped on a different one. These covers are readily available.
See here, for example:
https://ford.oempartsonline.com/oem-parts/ford-cover-k2gz6a949b
(This listing (all others, too) shows a Ford marking, but that's b/c it's a generic pic.)
Thanks! ? Truly appreciate the info.
mrs mighty
Sandee
Dallas
23 Bronco Sport
Some duplicates here from others’ posts …
Prices listed were from 2022 to mid 2023.
Accessories For 2022 Ford Bronco Sport Badlands with Premium Package
The list starting at “None of these were purchased” are FYI because I didn’t install anything from that list.
accessories
http://accessories.ford.com
Ford Parts
https://parts.ford.com/en.html
Bronco Sport Accessories
https://www.broncosportforum.com/forum/attachments/2021-ford-bronco-sport-accessories-sheet-part-numbers-and-prices-pdf.9124/
2022 Bronco Sport Parts
https://parts.ford.com/shop/en/us/parts/2022/ford/bronco-sport
CGS After Market Performance Products
https://www.cgsmotorsports.com/php/applications.php?makeid=4&modelid=89
https://fordauthority.com/2021/10/2021-ford-bronco-sport-by-cgs-performance-products-is-down-to-earth-sema-2021/
How to remove front grill
Home Depot: Coleman 24-Can plus ice Party Stacker Cooler, Blue Store SKU # 1000593501 Internet # 203639890: fits 2022 Ford Bronco Sport Badlands with Badlands Package Cargo Management System (Shelf/Divider/Table)
Exterior dimensions: 22” Length x 13.5” Wide x 8.25” Height
Interior dimensions: 16.38” Length x 11.13” Wide x 6” Height
Wide enough for a 13” x 9” dish
Depth 13.5”, Height 8.25”, Width 13.5”
Weight 5.7lbs, Total capacity 6 qts
Brand: SKTU, Screen Protector Foils for 2021 Bronco Sport SYNC3 8In Navigation Display Tempered Glass 9H Hardness Anti Scratch HD Clear LCD GPS Touch Screen Protective Film $12.84
Center console tray. Brand: ANMOSVO, Center Console Organizer for Ford Bronco & Escape - Console Armrest Dividers for Bronco Sport CX430 2021, Escape Hybrid Titanium 2020 2021, Storage Box Accessories with Anti- Slip Mat (Black Trim)
https://www.amazon.com/dp/B09FKWZ9NV/ref=cm_sw_r_cp_api_glt_i_Q0HEWY9WS07WV1JB63RW
2.75” (3” work better) car coaster, Brand: whkljyan, car Coaster 2 pcs 2.75” (Approximately 7.0 cm) car Cup Holder $8.79
Redline Tuning 2021+ Ford Bronco Sport Hood QuickLIFT PLUS Redline Tuning 21-11038-02 Hood QuickLIFT PLUS System Compatible with Ford Bronco SPORT 2021+ (All Black Components - Bolt in System) $99.95
Redline Tuning 2021+ Ford Bronco Sport Hood QuickLIFT ELITE 316L Stainless Steel 5yr warranty $140
TWO Byenins Large Slotted Universal Magnetic Jack Pad Weld Frame Rail Adapter (Orange) for All Model Cars, $13.99 each
Aluminum pinch weld pad adapter
Use with: Harbor Freight small low profile floor jack
Pinch welds: lift from when changing a tire
Rhino USA Shackle Hitch Receiver, Best Towing Accessories for Trucks & Jeeps, Connect Your Rhino Tow Strap for Vehicle Recovery, Mounts to 2 Receivers (2" Hitch Receiver) $50.68
Rhino USA Trailer Hitch Lock 5/8" Locking Receiver Pin for Class III IV Hitches Weatherproof Anti-Theft Lockable Pin with Dust, Mud & Gunk Protection $27.98
Set of four front and rear Door Sill Plates (BLACK PLATINUM PART NUMBER: VM1PZ-99132A08-B $81.77 or STAINLESS STEEL PART NUMBER: VM1PZ-99132A08-A $65.25)
FordParts.com
Bumper Protector - Rear
Part #: M1PZ17B807A (M1PZ-17B807-A)
MSRP: $63
GENUINE FORD SPLASH GUARDS FRONT GATORBACK HEAVY DUTY w BRONCO LOGO
Part Number: VM1PZ-16A550-A
$205.67 Levittown Ford Dealership
Alternate Part Number: VM1PZ16A550A
GENUINE FORD SPLASH GUARDS REAR GATORBACK HEAVY DUTY w BRONCO LOGO
Part Number: VM1PZ-16A550-B
Alternate Part Number: VM1PZ16A550B
Bronco area 51 license plate frame
window tint, Paint Protection Film PPF wrap (clear bra), Ceramic Coating full exterior
Fuse panel cover, interior, passenger side:
Instrument Panel Cover Passenger Side
M1PZ-78046A25-AA
Dash Panel Insulator, Part #: 78046A25
installed under warranty.
https://www.broncosportforum.com/forum/threads/anyone-else-missing-the-panel-under-the-dash-above-the-passenger-side-fuse-box-where-the-floor-air-ducts-are.5290/
Interior fuse block access: https://www.broncosportforum.com/forum/threads/interior-fuse-block-access.1627/
Dash Panel Insulator (under hood on firewall) M1PZ-7801588-A (40.63" L x 4.13" W x 0.5" H), 4X NUT-W709793-S439, Nut U Spring M6 Push On, 10/26/2020, BRONCO SPORT (C430N), EEC 70/157 AND ECE R901 PKG
FOBBVC-LG-K ABS Plastic Ford Bronco Black Tire Valve Stem Cap Covers $15.95 ($17.23) (Pack of 5) https://www.amazon.com/dp/B096CDFPV7/ref=cm_sw_r_cp_api_i_V0DQ2Y43QJ2NH9N56G09?_encoding=UTF8&psc=1
Ebony/Roast fold down rear seat headrests M1PZ-78611A08-EB
M1PZ-78611A09-EA
Costco Sun Shade: Type S Interior Auto Sunshade, Large? Jumbo?
$61 Sunscreen - Uvs 100 Custom - Ford VM1PZ-78519A02-A
WeatherTech
https://eclipsesunshades.net/
None of these were purchased:
Ford 2021 Bronco Emblem Overlay Badge Decal (REAR) $12.99
Genuine Ford Grille Lettering Gloss White
M1PZ-8A224-A OEM letters retail $160
$112.64 Levittown
https://www.broncosportforum.com/forum/threads/removing-grill-letters.1817/
Emblems: https://www.badbronco.com/
Genuine Ford Grille Lettering Gloss Black
Part Number: M1PZ-8A224-B
https://www.levittownfordparts.com/cat/2021-ford-bronco-sport-exterior-accessories.html?part_name=emblem
Genuine Ford Tailgate Lettering Gloss White $94.05, Part Number:
M1PZ-9942528-A Gloss White BRONCO
M1PZ-7842528-A Gloss White SPORT
Genuine Ford Tailgate Lettering Gloss Black
Part Number:
M1PZ-9942528-B Gloss Black BRONCO
M1PZ-7842528-B Gloss Black SPORT
“bronco sport chrome vinyl letters”
TVD Vinyl Decals: https://tvdvinyldecals.com/collections/decals-for-bronco/products/premium-cast-vinyl-decals-for-2021-bronco-grille?variant=39665118511219
2021 2022 Bronco Sport Decals & Stickers
https://www.vortexsigns.com/bronco-sport
Ford hood protector textured (rock guard, bug deflector)
avs aeroskin II matte black textured
Craven Speed Stubby Jr Antenna for 2021-2022 Ford Bronco Sport
SKU: CRMC-0705-499 $20 ships free
503-987-5045 [email protected]
https://www.cravenspeed.com/stubby-jr-antenna-for-2021-2022-ford-bronco-sport/
Wofins Carbon Fiber Central Control Gear Shift Panel Trim Cover for Ford Bronco Sport 2022 Front Gear Shift Panel Cover Interior Decoration Trim Kit Car Interior Accessories
https://www.amazon.com/dp/B09C23888P/ref=cm_sw_r_cp_api_glt_fabc_JEJ5KWDXE3SNYXKHNRT1?_encoding=UTF8&psc=1
BRONCO SPORT 2021-2022 CONSOLE VAULT REAR SEAT VEHICLE SAFE $299
https://www.stage3motorsports.com/1111-bronco-sport-console-vault-in-vehicle-safe.html
$429.00
VM1PZ9906202B (VM1PZ-9906202-B)
https://accessories.ford.com/collections/interior?pf_t_model=Model:+Ford_Bronco+Sport_2021&page=2
- Liftgate Privacy Curtain
- Interior Bike Rack BY YAKIMA Part Number: VM1PZ-7855100-B $172.63 https://www.levittownfordparts.com/sku/vm1pz-7855100-b.html
- Assistance Kit: On-Road $60
- Assistance Kit: Off-Road $210
- First Aid Kit $40
N/A: Front And Rear Splash Guards $220
Bulletpoint Mounting Solutions Install and Review
Secure: Phone, Tablet, Dashcam, Dash Cam, GoPro Action Camera, GMRS Radio (General Mobile Radio Service), CB Radio, Handheld Radio
https://www.broncosportforum.com/forum/threads/bulletpoint-mounting-solutions-install-and-review.9743/
RubiGrid 2021+ Ford Bronco Sport Platform Dash Mount Device Phone Holder
https://www.bulletpointmountingsolutions.com/products/rubigrid-2021-ford-bronco-sport-platform-dash-mount-device-phone-holder
20mm AMPS mounting balls
Expandable to up to 3 AMPS-Style balls
No pre-set locations. No limits.
https://www.bulletpointmountingsolutions.com/pages/amps-standard-patterns-explained
https://www.bulletpointmountingsolutions.com/pages/device-holder-help-faq
https://www.bulletpointmountingsolutions.com/collections/magsafe-compatible-phone-holders
https://www.bulletpointmountingsolutions.com/blogs/knowledge-base/create-your-own-magsafe-phone-mount-with-bulletpoint-components
LED Kit: diode dynamics
https://www.diodedynamics.com/rgbw-multicolor-footwell-led-kit.html
Option 1 (of many options): Sirius LED 7440 White Exterior Light Bulbs “FT”
50,000 hours LED Life
Plug and play, “200% brighter”
Ford Bronco Sport Owners: Darlene Bolin
SIR IUS LED - FT- 7440 LED Backup Reverse Light Bulb Super Bright High Power Single Filament function Air Vent Design 3030+4014 SMD White 6500K Pack of 2 https://a.co/d/8rygvEd
Option 2 (of many options): iBrightstar Newest 9-30V Super Bright Low Power 7443 7440 T20 LED Bulbs with Projector Replacement for Back Up Reverse Lights or Tail Brake Lights, Xenon White https://a.co/d/9eP8vha
OEM:
Backup, reverse lamp
Specification: W21W
Power: 21 Watts
LED Vanity Mirror Lights and Sun Visor Lights
Anourney 6PCS 28mm 29mm 6614F Festoon LED Car Bulb, Extremely Bright 9-SMD 4014 chips 6641 6612F LED Bulb, Fit for Vanity Mirror Lights and Sun Visor Lights, 6000k White
4.6* (5* 78%, 4* 11%) 2,735 reviews
6pcs $6.99
https://a.co/d/hrAwhYP
HyperTough 3 Gallon Oil Free Portable Air Compressor, 100PSI, ~200W, Red, Working pressure 0.7CFM at 40PSI, 0.5CFM at 90PSI $76.00 Walmart 19.29” L x 9.05” W x 13.98” H
Model: 0100311A
Wow!! I had no idea all this stuff was available. ? While on the topic of adds… anyone know where I can get a lighted Bronco emblem hitch cover? Please & thank you ??
Sojourner
Maryland
What a difference the last letter makes! k2gz6a949a is the non-existent Ford cover, while k2gz6a949b is the very available Lincoln one.
I followed a lead I found on the Maverick forum. Also followed that post and used an old Saab "2.0 turbo" badge. But any badge will work. Just have to secure it (the Saab badge had retainers on the back so it secured rather well; reinforced it with super glue).
BTW, the cover requires two bolts/studs (PNs, below). Readily available, though stupidly over-priced. The one you can see in the upper left..., I should have figured out out thread size/pitch and bought a bolt and washer from the local Ace. The one you can't see is under the cover on the right-side and acts like a holding stud. Not sure I could have found something similar at Ace. Didn't try b/c I had already bought the Ford parts.
AG9Z-00812-D Engine Valve Cover Grommet
1S6Z-00812-C Valve Cover Bolt
Ford Bronco Sport Pssst. Hey missing BS parts. Imma comin fo ya! Engine cover
kshaw
Kent
Gaithersburg, MD
You plug the Ottocast in instead of your phone. Once you pair your phone with the Ottocast in bluetooth, it hooks up automatically. I just leave the phone on the wireless charger.
$89.99 with Amazon coupon for Android Auto. Not bad.
https://www.amazon.com/OTTOCAST-Wireless-Android-Adapter-Converts/dp/B0C7QHC99L/ref=sr_1_4?crid=38OEA5C8CMI2B&keywords=ottocast+wireless+carplay+adapter+2023+android&qid=1703085811&sprefix=OTTOCAST+Wireless+CarPlay+Adapter,aps,93&sr=8-4&ufe=app_do:amzn1.fos.18ed3cb5-28d5-4975-8bc7-93deae8f9840
Oso Fell
Oso
NYC
23 Bronco Sport
Thanks for the pic and additional info! I like the 2.0 turbo badge.
Goodland
Jake
CA
This thread inspired me to finally order the folding rear headrests. I get unreasonably annoyed when I have to scoot the front seats forward to drop the rears. I absolutely hate it, and it only seems to be needed when I'm already holding or balancing an item that's too big to fit in the back. Whoever made the decision to ship without these should be sentenced to a thousand reps of loading a slightly-too-big item when the front seats are too far back to drop the rears.
Has anyone noticed an appreciable difference in noise reduction with the fender/hood insulation or interior dash pieces? I don't find the BS to be terribly loud, just curious.
Oso Fell
Oso
NYC
23 Bronco Sport
With the coup-like rear legroom the BSs have, foldable head rests are a must. Dropping the seats down to haul stuff regularly will be just that easier.
I find the BS the be surprising quiet on the road despite it have the shape of a Lego block. So me purchasing those missing insulation pieces is just to satiate my OCD. But if someone is on a tight budget, it can wait…
Oso Fell
Oso
NYC
23 Bronco Sport
Slowly but surely…
Ford Bronco Sport Pssst. Hey missing BS parts. Imma comin fo ya! IMG_1644
Ford Bronco Sport Pssst. Hey missing BS parts. Imma comin fo ya! IMG_1643
Thanks to all my BS peeps for the awesome info!! ?
*I’ve decided to keep the Lincoln emblem on the cover. I believe it adds 2HP to overall output. ?
Bill G
San Gabriel Valley, CA
Now you’ll have to start cutting the crust off your sandwich — Merry Christmas!
