Ugly mpg with 1.5..Help
Alfa 2407
Thomas
Dummy me!!! what is ILOM ? I only drive about 5k annually and change oil at that interval at the Ford place. But I do remote start my engine for 15 min timer on almost every day that I don't drive it. Is that considered extreme? Could that also cause higher fuel comsumption in my case.
To start, I have no idea what ilom actually stands for but I'm guessing by context it has to do with the oil life monitor calculation, and no it shouldn't, to my knowledge, not if its just for 15 minutes, keep in mind I'm talking about running idle for 1hr+ for 5 days a week
Intelligent Oil-Life Monitor. Check the Scheduled Maintenance section of you Owner's Manual. It's on page 394-395 in mine.
thomasm23
Los Angeles Metro
Check the condition of your engine air filter. I assume it has never been changed. Do you have the OEM air filter still installed?
Just remove the filter and tap it on a hard ground surface until the dust no longer shakes out and reinstall.
Also check for any blockage around the air filter box and the fresh air intake coming into the box. The fresh air comes in from the bottom of the box.
This is what the Motorcraft OEM filter looks like.
Ford Bronco Sport Ugly mpg with 1.5..Help IMG_4033
I wouldn't idle for a half hour or so to download an update and you idle one hour 5x a week . Wow!
Radioman
Radioman
Dale
Mccomb ms
2021 Ford bronco
Alfa 2407
Thomas
Yeah, not something I like to do, but in this 95-110° heat with a dark color car, it's absolutely necessary
Alfa 2407
Thomas
Good to know, I'll be sure to do some reading on it when I have the time
The engine uses the most fuel when cold, so if you are idling a cold engine for 15 minutes every day that could definitely affect your fuel economy. The PCM keeps the mixture extra rich to get burning fuel out of the exhaust valve in each cylinder and down to the catalytic converter. The intent is to get the catalytic converter up to operating temperature as rapidly as possible, mainly because it doesn't do its job of scrubbing exhaust gasses until hot.
Instead of idling every day why not just put a battery charger on the night before you intend to drive it?
You dont need to run it for 15 minutes on days you dont drive it unless its winter and you live in Artic Circle or something. Just let it sit as long as vehicles don't sit for months without running they will be fine. Sitting days even a couple weeks in normal like climates shouldn't hurt anything.
larry_kak
Larry
Illinois
New Outer Banks, 1300 miles, best I can get mileage wise on the road is 25 even in econ mode, should I be checking something? Is there a break in period before I get netter mileage?
davidg4781
Just an update from yesterday...
I had filled up I think on Monday. On my commute to work and home, the BS was showing 10 mpg. Yes, I need to start tracking it on my own.
Driving out of town mostly at 75 mph doing some spirited driving when I got to the big city, and after sitting here idling while I install these updates, I'm at 19.7 mpg.
It has to be the short commutes with frequent stops/starts.
If I lived in an area that required me to idle the engine to warm it up, I'd get a engine block heater. Keeps the block warm during night time (or prolonged sitting).
Sensei
Sid
Georgia
Ever since putting larger tires on my MPG hit the basement! 22. It REALLY killed gas mileage.
