- First Name
- Kevin
- Joined
- Mar 16, 2023
- Threads
- 55
- Messages
- 2,494
- Reaction score
- 3,709
- Location
- Gainesville
- Vehicle(s)
- 2023 Ford Bronco Sport Outer Banks Area51
When it comes to a powerplant such as what we have in our BS's, some folks think they can better engineer the engine for more power and reliability then what the auto engineers that designed it came up with.Yup. And as I mentioned, I find it difficult to believe that Ford's engineers didn't put thought into optimizing the OEM systems for the power delivery goals it had in mind. The other big issue you run into when you start mucking with power delivery is driveability. It's almost a certainty you can get significantly more power out of a modified 2.0L engine than what Ford advertises for the engine in OEM trim. You can add a larger turbo, bigger air filter, larger charge and down pipes, bigger diameter exhaust pipes, higher pressure fuel injectors, etc., ect., ect. All of that would serve to get more air in and out of the engine so you can burn more fuel and generate more power. But what often happens is while the engine DOES produce more horsepower, the turbo takes so long to spool up you don't actually get any of that extra power until the last couple thousand RPM before you hit the engine's redline. This makes for a dreadful driving experience everywhere except a race track where you can manipulate the throttle and brake to keep the turbo spooled up all the time. Imagine trying to drive you car off-road in this condition, where you need controllable torque at low RPM.
Sounds great for a sports car, but not so much for an off-road adventurer.
Or, they have money wasting away in their wallet or PayPal account.
If it's power that's wanted, there are so many other choices out there to play with.
