- First Name
- Robert
- Joined
- Mar 23, 2021
- Threads
- 2
- Messages
- 1,322
- Reaction score
- 1,896
- Location
- California
- Vehicle(s)
- Bronco Sport
The 1.5 needs every advantage it can get, premium is the way to go and owners manual corroborates such.
Is there such a thing as premium/high test amps?Man, I hope they don't ask these obvious questions on the Tesla forums ...
Yes. Premium comes from wind and solar. Regular comes from coal.Is there such a thing as premium/high test amps?
The 1.5 isn't that bad, why people go on about it I don't know. I don't think people can wrap their heads around the fact that it's a 3 cylinder. Is it fast, no, but it gets the job done just fine. Premium did zilch for performance. Even in hot weather, I doubt the butt dyno will register anything at all. Better off removing excess weight and passengers, that will make a noticeable difference.The 1.5 needs every advantage it can get, premium is the way to go and owners manual corroborates such.
It probably doesn't help since Ford's a bit vague on the benefits of using 91.Man, I hope they don't ask these obvious questions on the Tesla forums ...
Top Tier.Which fuel is recommended for the 1.5?
I find the 1.5 perfect for my needs. Even the 2.0’s aren’t fast, it’s a brick on wheels.The 1.5 isn't that bad, why people go on about it I don't know. I don't think people can wrap their heads around the fact that it's a 3 cylinder. Is it fast, no, but it gets the job done just fine. Premium did zilch for performance. Even in hot weather, I doubt the butt dyno will register anything at all. Better off removing excess weight and passengers, that will make a noticeable difference.
"The performance gained by using premium fuel is most noticeable in hot weather as well as other conditions, for example when towing a trailer."
Just a simple question cause it's not really defined in anything that I've readMan, I hope they don't ask these obvious questions on the Tesla forums ...
Are you drunk? You already gave that answer.Nitro Methane
Some guys never heard of it. Lol quit drinking 20 years ago.Are you drunk? You already gave that answer.
Although you shouted it out for some reason in your first post.
Nitro Methane
[/QUOTE
I just passed 22K on my BS OB. Since new I have tried 87, 89 and 91 octane, both ethanol and ethanol free fuel. I track milage and mpg every at tank fill-up. Here is what I found.
The engine needs to be fully broke in before the numbers start to show a pattern. Generally 3K is good but 6K is better. After that the difference in types of fuel and octane becomes more noticeable both at the peddle and on paper.
For daily commuter 87E is fine, inexpensive and easy to find. Higher octane fuel gradually increases mpg. If towing or hauling cargo and people then the higher octane fuel is better, especially in hotter climates. The best performance and mpg is from ethanol free, 90 or better.
The caveat being the price is higher and E free is harder to find. The increase in mpg and towing performane comes at a price. In my case I noticed the engine runs smoother as well. Is it worth the extra cost, from the standpoint of economics probably not. From a performance point of view definitely noticeable. Bottom line is what you are using your BS for and if you are willing to pay extra.
I will continue with E free 90 if the price stays within my comfort zone. If we have another spike in fuel costs I mught go back down to E87. I have to say once you get used to the little extra performance and mpg its harder to go back to 87, its that noticeable.
