HRG 1.25" Lift vs. Woolworth Motorsports 1.25" Lift (Badlands) (1.5" For Other Trims)
jkbronco
Kenny
Illinois
www.jkbronco.com
2021Bronco Sport
Did you use the camber bolts? I purchased them but will probably take them to the alignment shop if they are needed
Yes we used the Bolts. Once the tires get in we are getting a 4 wheel alignment and getting the spacers and tires installed.
BamaBronco
TJ
Alabama
How and where do the bolts install? Are the bolts necessary after getting an alignment, or would they be required first to even get an alignment after installing the lift? I've seen that they are an accessory with the HRG lift but am wondering how critical they are.
They are cammed bolts installed in the strut mount to allow camber adjustment. Camber is the vertical angle of the wheel/tire, i.e. top tilted inward or outward. I've not heard anyone mention the need for a camber adjustment following the installation of a lift kit, but if you take it for an alignment and the shop cannot get the camber adjustment within spec then you'll need the camber bolts.
BamaBronco
TJ
Alabama
Thanks for the information. I knew they were for camber adjustment, but I had never heard of using special bolts to do it. I also wasn't sure where they would even be installed to help in making the adjustment.
This video explains how they work.
Adam06
Adam
New Mexico
Bronco sport big bend
So just got back from my alignment. Went to Firestone because of the life time alignment but they did not have the software for the bronco sport. So ended up at ford quick lane and indeed the camber bolts are need to get it aligned.
There you go. Frankly, I was surprised anyone was able to lift one of these cars without inducing a change in camber.
jkbronco
Kenny
Illinois
www.jkbronco.com
2021Bronco Sport
jkbronco
Kenny
Illinois
www.jkbronco.com
2021Bronco Sport
Did you use camber bolts?
Yes the front we used the camber bolts. the rear has 2 adjustable bolts simliar to the camber bolts to get the wheels aligned.
RiotfunK
Mass
22 Bronco Badlands
The Woolworth kit looks like they cheaped out on parts. The subframe spacers are tack welded and open so will fill with debris etc. plus a lot of force on those. Cause a wear point on the body. Looks like lower grade shoulder bolts. The whole kit looks like it’s a RC kit with extra parts. I watched the dudes install video and I wouldn’t use their setup. Again looks cheap. HRG or Ford Ranger lifts are the only ones that are well built, plus the owners know their stuff. I have no affiliation to these guys. Just know what quality parts look like and you can actually talk to them. They know their shit.
Digitalexcess
Scott
South GA
Uhm.... Robby Woolworth is the owner of Ford Ranger Lifts, so which ones know their stuff?
Ford Ranger Lifts - Ranger, Ford Ranger, Lifts, Truck Accessories
RiotfunK
Mass
22 Bronco Badlands
I guess not me lol. What I got sent looked like different parts than what I saw online in a video. Maybe was early build of parts, don’t know. Dude was cool though, talked to him at length and knew his stuff. Trying to help folks with lift stuff with good options not make it harder. Waiting on my BL and then tear into it to fab some my own parts since there isn’t a ton of options. So my bad. But I’d still use either ones setup over the others out there after talking to them and seeing what I was sent
Beezzer
Brian
Kentucky
Are these factory or did you purchase them? My front camber is fine but the rear is so bad it has destroyed my new BFGs.
dakman
I've had the same thing happen. When I had it aligned after the lift they told me they didn't have specs on the vehicle yet but they could do it. They did a good job on my ST so I trusted them. 15k miles later my rear tires have worn on the outer edge bad. Front is fine. Don't think they adjusted the back at all, it wore exactly how you would expect with a small lift.
