When did you get your BS? Your dash layout is a little different, the temp and gas gauge along the bottom, and the chrome ring around the rpm/speedo.750+ Miles, took two trips into the mountains and 70/30 Hwy/Cty driving.
I was tracking MPG the old way, like my grampa did, with pen and pencil but to be honest it was within +/- .2-.5 MPG of the digital readout.
He has the Outer Banks. It has a different display than your Big Bend.When did you get your BS? Your dash layout is a little different, the temp and gas gauge along the bottom, and the chrome ring around the rpm/speedo.
Here's my dash, BS purchased Sept 2021.
I'm struggling to get above 28mpg, with 245's. Best I've ever had is low 28's, calculated manually. The mpg on the screen as about 2 higher than manual calculating.
The “fancier” models got a different gauge package.When did you get your BS? Your dash layout is a little different, the temp and gas gauge along the bottom, and the chrome ring around the rpm/speedo.
I wish I had those fuel and temp gages on the OBMy base model dash picture, simple, clean.
Colder temps means denser air which requires a bit more fuel. It also means a drop in tire pressure which increases rolling resistance.Last summer my best was 33-34 mpg. That was with mid grade fuel and using cruise on the highway. Now in winter with using remote start more I seem to get around 27.
And longer warmup times, which keeps the mixture rich.Colder temps means denser air which requires a bit more fuel. It also means a drop in tire pressure which increases rolling resistance.
EPA estimates 25 mpg city for the 1.5L Bronco Sport, so it sounds like you're right in the ballpark.I just filled up 2nd tank. Od 686 (321 mi), filled 13 gal. Avg mpg: 24.7. This tank full represents almost entirely city driving and the weather over the last week was bitterly cold with highs between 0 and 10 degrees for the high and early mornings in the minus temps. And snow! Roads snow covered and icy.
