Unofficial MPG thread for the 1.5L
Was getting roughly 27MPG combined....added larger tires (WP AT3 235/65/17) and a front runner roof rack.....am now getting 22.5MPG. Gotta be honest, I am a little disappointed by the drastic loss. I knew there would be some, but this is a bit much.
The taller you make the vehicle the more wind affects fuel economy. In addition, the larger tires are heavier and add to the rolling resistance. Life is full of tradeoffs...
BroncoNamedSarge
Leslie
Belton TX
Bronco Sport Big Bend
I understand that, but losing roughly 5mpg seems excessive. I also wanted to add a 1.5" lift, but am afraid it will drop the MPG below 20. At that point, I might as well have purchased a full sized Bronco.
If you get a full-sized Bronco, lower it and put narrower tires on it you'll get better fuel economy with it.
dejones64
Dan
MN
Lancer, BS BB
I've been keeping an eye on my mpg since I got my Big Bend last Sept. I put 245/65/17 tires on the first day. I'm in MN, dang cold in the winter. I run 89-93 octane.
During those warmer months I was getting about 27-28 manually calculated. I could never get the dash display into the 30's, like some others out here. During the winter months I was manually calculating 25-27. With the recent warm up, last 2 tanks of gas, I've been able to get the dash display over 30, manually recorded a high of 29. The dash display and manual calculation has been 1-2 mgp difference.
11k miles on it, should be broken in, with the warm season coming up, I'm hoping on consistently getting at least 30mpg.
BroncoNamedSarge
Leslie
Belton TX
This makes me believe that the largest loss for me is the rack. What the heck? I really only use it in the winter to go snowboarding. I may remove it for Spring and summer. Ugh!
dejones64
Dan
MN
Lancer, BS BB
I thought the larger tires were a mpg issue too, but others with larger tires were still getting good mpg. And mine is starting to go up.
I have noticed though if I'm going into a headwind, that will really knock down mpg. I'm sure once I put on a roof top tent I can forget about mpg.
DMEARC
2019 Mustang, 2021 BS OB
On average a roof rack will drop MPG by as much as 10%. In your case, that’s almost 3 MPG. It’s recommended to remove any accessory from your roof if you are not actively using it.
Bron Swanson
Interesting! I can't imagine ever using the rack, so this could be a good way to save some money on gas.
I just googled how to remove the rack, and I can already tell it is a frustration I don't want in my life :cwl: . Whenever I take my BB in for its first service at Ford, I will inquire if they can do it there.
Bron Swanson
My prediction is that with warmer weather on the way you'll see an increase in fuel economy. Unless you live somewhere without seasons, like FL or CA.
For 93, I reset trip 2 and gave it around 1,000 miles for a test. I got roughly 30 mpg.
For 87, I reset trip 2 again and have given it 500 miles so far. I am at roughly 29 mpg (and it is slowly creeping up).
I think I can stomach a 1 mpg-or-less difference in order to save $8 per tank of gas :cwl:
Bronco307
Kade
Wyoming
22 Badlands, 22 Big Bend
The roof rack most likely accounts for the loss in the mpg, they look cool but boy do they mess with your aerodynamics, especially at high speed. If you have it on just for looks, try taking it off for a couple of tank fulls, you'll likely see a big difference in efficency.
That sounds like a good tradeoff to me too! Has there been much of a change in temperatures since you started using regular?
Bron Swanson
Compared to when I was testing the 93, It is probably about 20 degrees warmer on average.
Barring drives to some family a few hours away, I normally only drive about 22 miles a day (and less on weekends). Thus, a single tank lasts a good long while for me. I expect temps in the 60s on average by the next time I need to put another tank in.
DMEARC
Exactly. Engineers go through a lot of trouble to fine tune the exterior of vehicles for better aerodynamic efficiency, and then we ruin it by attaching all sorts of stuff to the outside of our vehicles. Generally speaking, when you double your speed your drag is quadrupled. So a roof rack that generates 40 pounds of drag at 40 MPH will generate 160 pounds of drag at 80 MPH. That’s a lot of extra work for your engine.
An interesting article about this topic can be found here: https://www.consumerreports.org/fuel-economy-efficiency/how-rooftop-carriers-affect-fuel-economy/
My neighbor has a Subaru with big chunky tires and a roof rack with a huge spare tire sitting in it. She doesn’t off-road the car, she just likes the way it looks. I can’t imagine the loss of MPG she’s suffering, especially at today’s gas prices. Is it really worth it?
DMEARC
Do you mean the roof rails? Those are integral and not meant to be removed. I was referring to anything you attach to those rails: roof boxes, kayak carriers, spare tire carrier, etc.
