EDITED 7/22/2023:
some owners choose to always leave automatic updates disabled so it’s a choice every owner can make based on their experience and information.
Original May 7, 2023 post:
At this time I recommend you do not install SYNC Version 3.4 Build 23088 and recommend disabling automatic software updates to prevent the possibility that Build 23088 gets automatically installed.
There maybe an issue with SYNC Version 3.4 Build 23088 (or with other updates) that may corrupt the Sync software installed on the APIM (Accessory Protocol Interface Module).
Owners have reported various issues (see links below).
TSB 22-2254 SYNC 3 - Various SYNC Symptoms, SYNC Screen Flicker, Echo/Robotic Voice Concerns, Temperature Not Displayed In Pop Up Screen
https://community.cyanlabs.net/uploads/short-url/xzlS3pmnyk4POB8ROhWjOu1fqOk.pdf
Recommend using the 8” Display under Settings to disable automatic software updates. Instead manually install your own Sync updates over USB “awhile” after a Sync 3.4 update comes out after checking to be sure there aren’t issues with the Sync update.
FYI, this cyanlabs post claims 23088 is same as 22251:
https://community.cyanlabs.net/t/new-sync-3-version-3-4-23088-still-3-4-22251-actually/8954
Also see:
https://www.broncosportforum.com/forum/threads/sync-3-4-build-22251-default-issue.8699/
22251 and 23088
Sync 3 Memory Issue
https://www.f150forum.com/f118/sync-3-memory-issue-538739/
Recurring Sync Pop up
https://www.f150forum.com/f118/recurring-sync-popup-539949/index2/
New SYNC Version 3.4.23088
https://www.explorerforum.com/forums/threads/new-sync-version-3-4-23088.502652/
Also see:
22251 and 23088
Sync 3 Memory Issue
