- First Name
- Tomas
- Joined
- Jun 2, 2024
- Threads
- 7
- Messages
- 1,066
- Reaction score
- 1,427
- Location
- Sacramento
- Vehicle(s)
- 2024 Bronco Sport Badlands
- #151
Two more items came in the mail today. The @Underground Graphics light smoke over lay to install on the new passenger side tail lamp. And going with the z36 pads this time. I looked into upgrading the rear rotor size like I've done on my ST but the rear is already 302mm which is the same on the Maverick. Rangers and explorers are 5x114.3 bolt pattern so those rotors won't work. And the electronic parking brake on the caliper bracket makes it more difficult to find a compatable swap also. The front rotors are 308mm so I've scrapped the idea realizing i cant really go much bigger in back, and it would be kind of ridiculous to put some brembos in front. I was hoping it would be easier like on the focus. Might look further into steel braided lines. I've always thought the brakes on these were terrible. Maybe if I would've just put the z36 instead of the z17 it would've stopped better. I figured it was overkill and the 17 were fine. They definitely stopped better than stock.
I told the collision shop to reinstall the damond brass bushings on the caliper bolts, hopefully they did. Whole hub assembly needed to be replaced on that side. Also have the hood struts in box.
Ill probably re order the rear side markers again. Looking at pictures i noticed the rear bumper lights actually didnt take a hit. And one more big box is paid for but not quite on the way yet.
i should order flasher module too. I'm thinking of just putting it on the 3rd brake light. Maybe on the rear facing bumper lights, but the change from dim to high on those chinesium lamps is not really super noticable.
It would be different to put it on the running ring light portion of the tail lamp, but not quite sure if I could do that. Since signal to initiate module would be from brake lamp. Something I'll have to play with.
One thing is for sure I'm over this camry loaner. Reminds me too much of the wife's old subaru
