OEM Replacement Valve Stem Caps
davidb1841
Bruce
NC
I was also going to put a smart butt comment here......until I saw the post about license plate screws......
Never mind..........
kshaw
Kent
Gaithersburg, MD
If you are serious about tire stem caps, you should get some that meet MILSPEC MS-20813-1. Those are all brass and have a seal that is good for 0-5000 psi and -65° F to 160° F temperature range. They only come in yellow, though and cost under $2 each.
Opposite end of the serious spectrum must be these all plastic caps meeting no specs at $3+ each
Ford Bronco Sport OEM Replacement Valve Stem Caps IMG_7033
I bought a box of 100 super extremely boring Dill 630 caps for my car. Now the tire boys can throw away as many of my "special" caps as they like. I have dozens to replace them.
Ford Bronco Sport OEM Replacement Valve Stem Caps 630n
I’ll stick with these. I found them on Amazon. Available in Grey, Black, Orange and Red.
Ford Bronco Sport OEM Replacement Valve Stem Caps C0C56940-EE99-4A64-8BD4-4CAC22968554
I have found that each time I buy a set of snazzy valve stem caps, they disappear within a month.
I guess some folks seem to think they look better on their cars, or kids like them on their bikes.
Back to boring black stem covers for me.
B-Dog15
Brandon
Covington, Ky
I got some fancy red ones with the Bronco logo on the front just so I can match the red accent theme I have going. 100% not worth the money but would I do it again? ? Probably
bronco68halfcab
Stephen
Clarksville,TN
'68 Bronco, '78 Granada, '11 F150, '24 BS
What are MILSPEC valve caps? This is what I get when I order valve caps through the Army Supply System. 100 of them for $3.03, but they do have a rubber o-ring inside. The Army calls for these on the HUMVEE, 2 1/2 ton, 5ton and 10ton HEMTT trucks.
Ford Bronco Sport OEM Replacement Valve Stem Caps PXL_20240815_122716748
bronco68halfcab
Stephen
Clarksville,TN
I like the yellow caps better than the black plastic Army ones.
Bill G
San Gabriel Valley, CA
IF the military supplies it — it has a “milspec” and a number somewhere. There’s a milspec on the “skivvy” shorts they issue ?
kshaw
Kent
Gaithersburg, MD
