I think it's a bit of both.I’m no mechanic but I worked at a Toyota dealership as a lube tech for a minute and reading this thread is blowing me away. Even the stoner 18 yr olds I worked with checked all of the things you guys are mentioning. Every single vehicle had fluids, lights, tire pressure, brake pads and battery checked. And they were honest about it too. Any mechanical issues were only noticed if there was a leak that shouldn’t be there, which was also a part of the service, a full under carriage inspection. Hopefully that’s dealer specific and not a bigger problem amongst Ford cause leaving an empty coolant reservoir is so blatant.
If the service manager is saying get these cars out quick, just make sure they're not bone dry or whatever, that's what they're going to do. If they're double checking them, getting on them if customers complain, they'll do better.
I came from Honda for the last 10 years. My two local dealerships were mediocre. One would spill oil all over the engine (did it three times with us) and not clean it up. The other I noticed would not fill fluid levels. We had oil changes A and B, B was more extensive. I would take mine up to Austin to a dealership I used to go to when it needed a B. It was a nice drive and I trusted them to make sure they took care of it.
