NEW PRODUCT! Bronco Sport 2 Inch Level Lift $449
Status
Not open for further replies.
Magnato1
Jeff
https://flatoutsuspension.net/products/bronco-2level
Ford Bronco Sport NEW PRODUCT! Bronco Sport 2 Inch Level Lift $449 Flatout Bronco 2
This entry-level lift kit allows you to lift the front of your bronco sport 2" and the rear 1.5" (1.5/ 1.0" on Bad Lands/ First Edition) for a level lift. The rear is on a height adjustable perch which will allow you to do a 2" lift (1.5" on Bad Lands/ First Edition) front and rear and retain the natural rake (0.5" higher rear) for a true 2" lift if desired.
The front uses a 2" (50.8mm) spacer that sits atop the OEM strut. The rear uses a height adjustable spring perch and new springs. You can choose between a comfort spring which retains the OEM rate and load capacity or an overload spring which increases load capacity perfect for hitch mounted cargo baskets or rear tire carriers eliminating sag.
Kit includes:
2x 2" Front strut spacers
2x Adjustable sway bar endlinks
2x Camber adjustment bolt
4x Rear trailing arm spacers
2x Rear Springs (comfort or overload)
2x Height adjustable rear spring cups
2x Rear brake line extension bracket
1x Perch adjustment wrenches
2x Flatout Suspension decals
Approximate install time : 2-3 Hours
Why buy our kit instead of the others on the market? While spacer lifts all serve the same function, most of the kits out there only lift 1.5" and do not allow you to level the ride height. Our spacer is slightly offset to maintain proper camber and caster to prevent tire wear. Other spacer kits do not accommodate a way to increase cargo/ load capacity as they reuse the OEM rear springs.
If you set rear height above 1.5", we advise adding our subframe spacers as well to re-center the rear tire and reduce the angle of the CV.
https://flatoutsuspension.net/products/ford15spacer
What is the max tire size with this kit?
Bluejaye
Jaye
Detroit
2023 Bronco Sport Heritage Limited
What's a "Subframe Spacer Kit" and why would I want, or not want, one? Thanks.
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
www.flatoutsuspension.net
2022 BS OBX
Subframe spacers drop the subframe to cancel out geometrical changes from the lift. Corrects cv axle angle, etc. Above 1.5” lift, we highly recommend it.
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
2022 BS OBX
Hooray!! A review is in!
(Posted to our site)
Title: Great lift option!
Rating: 5 stars ⭐⭐⭐⭐⭐
Author: Brandon G
The full coilovers offered by Flatout are out of my budget, so when these were released I decided to go for it. The box was packed very nicely, instructions were very thorough. The shop had no issue installing them. I went with the comfort option which I think keeps the OEM rate (though I’ll switch to overload once I install a tire swing). I set the rear to 1 1/2 inches so the Bronco is sitting level. High quality parts and looks great. Now I just need some proper tires! Thanks guys!
I'd love to know how much your shop charged you to install. I'm hoping you'll take it out on the trails as soon as it is done and give us a full review. Thanks.
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
2022 BS OBX
Another review!
Title: It’s absolutely perfect
Author: Brian B
This thing is incredible. High quality parts, design, and looks are apparent from the time you open the box. The guys at my shop could not believe what was put into this compared to other lifts at this level. The customer service was TOP NOTCH throughout the process. HIGHLY recommended!!
Ford Bronco Sport NEW PRODUCT! Bronco Sport 2 Inch Level Lift $449 0A576078-EF59-4C9A-B77D-FFD7366D96F3
B5G4B
2022 BRONCO SPORT
I was just going to create a separate post for this as it is my vehicle. TOTALLY love this lift. My shop charged me for 3 hours labor and an alignment. It was pretty straightforward and Flatout Customer Service answered any and all questions and went above and beyond at every step. Feel free to message me with any questions about this product. I could not be more pleased!
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
2022 BS OBX
By all means, create another thread! ?
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
2022 BS OBX
austin3.16
Austin
Just a tidbit of info because people ask...
On comfort springs, we went from a 33" (ground to 12 o'clock on the arch) to 31.75" with 15 bags of mulch.
I feel like that's relevant information.
Can you show pics of the rear spring perch? Curious how high you put the collar. I set mine 1.5” up and I’m basically level with the front. Wanted to get the rear up a bit higher
B5G4B
2022 BRONCO SPORT
Ford Bronco Sport NEW PRODUCT! Bronco Sport 2 Inch Level Lift $449 IMG_2494
Status
