- First Name
- Jeff
- Joined
- Nov 17, 2021
- Threads
- 5
- Messages
- 38
- Reaction score
- 25
- Location
- California
- Vehicle(s)
- Bronco Sport
What is the max tire size with this kit?Bronco Sport 2 Inch Level Lift $449
https://flatoutsuspension.net/products/bronco-2level
This entry-level lift kit allows you to lift the front of your bronco sport 2" and the rear 1.5" (1.5/ 1.0" on Bad Lands/ First Edition) for a level lift. The rear is on a height adjustable perch which will allow you to do a 2" lift (1.5" on Bad Lands/ First Edition) front and rear and retain the natural rake (0.5" higher rear) for a true 2" lift if desired.
The front uses a 2" (50.8mm) spacer that sits atop the OEM strut. The rear uses a height adjustable spring perch and new springs. You can choose between a comfort spring which retains the OEM rate and load capacity or an overload spring which increases load capacity perfect for hitch mounted cargo baskets or rear tire carriers eliminating sag.
Kit includes:
2x 2" Front strut spacers
2x Adjustable sway bar endlinks
2x Camber adjustment bolt
4x Rear trailing arm spacers
2x Rear Springs (comfort or overload)
2x Height adjustable rear spring cups
2x Rear brake line extension bracket
1x Perch adjustment wrenches
2x Flatout Suspension decals
Approximate install time : 2-3 Hours
Why buy our kit instead of the others on the market? While spacer lifts all serve the same function, most of the kits out there only lift 1.5" and do not allow you to level the ride height. Our spacer is slightly offset to maintain proper camber and caster to prevent tire wear. Other spacer kits do not accommodate a way to increase cargo/ load capacity as they reuse the OEM rear springs.
If you set rear height above 1.5", we advise adding our subframe spacers as well to re-center the rear tire and reduce the angle of the CV.
https://flatoutsuspension.net/products/ford15spacer
