NEW PRODUCT! Bronco Sport 2 Inch Level Lift $449
Status
Not open for further replies.
Flatout Suspension
Gold Sponsor
Maryland
www.flatoutsuspension.net
2022 BS OBX
https://flatoutsuspension.net/products/bronco-2level
Ford Bronco Sport NEW PRODUCT! Bronco Sport 2 Inch Level Lift $449 Flatout Bronco 2
This entry-level lift kit allows you to lift the front of your bronco sport 2" and the rear 1.5" (1.5/ 1.0" on Bad Lands/ First Edition) for a level lift. The rear is on a height adjustable perch which will allow you to do a 2" lift (1.5" on Bad Lands/ First Edition) front and rear and retain the natural rake (0.5" higher rear) for a true 2" lift if desired.
The front uses a 2" (50.8mm) spacer that sits atop the OEM strut. The rear uses a height adjustable spring perch and new springs. You can choose between a comfort spring which retains the OEM rate and load capacity or an overload spring which increases load capacity perfect for hitch mounted cargo baskets or rear tire carriers eliminating sag.
Kit includes:
2x 2" Front strut spacers
2x Adjustable sway bar endlinks
2x Camber adjustment bolt
4x Rear trailing arm spacers
2x Rear Springs (comfort or overload)
2x Height adjustable rear spring cups
2x Rear brake line extension bracket
1x Perch adjustment wrenches
2x Flatout Suspension decals
Approximate install time : 2-3 Hours
Why buy our kit instead of the others on the market? While spacer lifts all serve the same function, most of the kits out there only lift 1.5" and do not allow you to level the ride height. Our spacer is slightly offset to maintain proper camber and caster to prevent tire wear. Other spacer kits do not accommodate a way to increase cargo/ load capacity as they reuse the OEM rear springs.
If you set rear height above 1.5", we advise adding our subframe spacers as well to re-center the rear tire and reduce the angle of the CV.
https://flatoutsuspension.net/products/ford15spacer
Tigger
Tigger
Illinois
“(1.5/ 1.0" on Bad Lands/ First Edition)”
Why doesn’t anyone ever mention the Heritage Limited (or the Heritage)? Are they looking at Wikipedia which still does not have these trims?
https://en.m.wikipedia.org/wiki/Ford_Bronco_Sport
But otherwise, this looks cool. Nice job!
edit: I updated Wikipedia to include the Heritage trims
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
2022 BS OBX
Yeah, forgot that…it’s newish and not part of my normal thought.
PugDad
Bronco Lilly
Newfoundland,Canada
BSBL
It’s ok Tigger we never forget about you. Mainly because you won’t let us!! But that’s another story. ?
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
2022 BS OBX
Just a tidbit of info because people ask...
On comfort springs, we went from a 33" (ground to 12 o'clock on the arch) to 31.75" with 15 bags of mulch.
I feel like that's relevant information.
entry-level lift kit?
B5G4B
2022 BRONCO SPORT
Got mine in today. Installing later this week. Anybody done this and have pics yet?
Flatout Suspension
Flatout Suspension
Gold Sponsor
Maryland
2022 BS OBX
Hooray!! No pics that I've seen yet.
I'd love to hear your initial impressions...packaging, overall appearance on quality, etc.
B5G4B
2022 BRONCO SPORT
Wanted to follow up as promised. This is an awesome kit folks. Not only are the parts clearly high quality, the blue absolutely pops and looks great. The adjustable rear pieces are super cool. Was packaged very professionally and came w some Flatout swag that I will proudly display when I get this installed early next week. I will post a pic when my shop gets it done.
Ford Bronco Sport NEW PRODUCT! Bronco Sport 2 Inch Level Lift $449 IMG_2288
Status
