The new A/T4W will be phased in as the 3W is phased out. They look a little heavier to me, (check the tire specs) https://www.falkentire.com/wildpeak/at4w
My thoughts and corrections.Hereās the data for 3 tires for comparison. Confirm all numbers are accurate before using this data. Links to the Specs are provided.
Falken Wildpeak AT3w OEM (Bronco Sport optional tire)
Where made: Thailand or Japan or Buffalo
Item number OEM part# 59000690 (for Ford)
Tire size 235/65R17
Load ID SL
Ply rating --
Service desc. 104H
Approved rim width (in) 6.5 - 8.5
Measuring rim (in) 7
Overall diameter (in) 29.1
Overall width (in) 9.6?
Revs per mile
Tread depth (/32) 13?
Tire weight (lbs) 31
Max Load Single / Dual (Ibs) 1984
Max Pressure (psi cold) 50?
UTQG: 600 B A
Warranty 5 Years / 55,000 Miles
Spec Link: OEM part# 59000690
https://www.tires-easy.com/235-65-17/falken-tires/wildpeak-a-t3w/tirecode/59000690
https://www.falkentire.com/wildpeak/at3w#size-list
WILDPEAK A/T4W
Item number 28841790
Tire size 235/65R17
Load ID SL
Ply rating --
Service desc. 104H
Overall width (in) 9.4
Revs per mile 731
Tire weight (lbs) 38.2
Max Pressure (psi cold) 51
UTQG: 600 A A
Warranty āup to 65,000 Milesā
Spec Link:
WILDPEAK A/T4W
Item number 28844768
Tire size 245/65R17
Load ID XL
Ply rating --
Service desc. 111T
Approved rim width (in) 7.0 - 8.5
Overall diameter (in) 29.5
Overall width (in) 9.8
Revs per mile 719
Tire weight (lbs) 41.9
Max Load Single / Dual (Ibs) 2403
UTQG: 600 A B
Spec Link:
Yes I thought there were some typos both in the A/T3W, 235/65/17 OEM part# 59000690 data I posted as well as in Falkens specification info for A/T4W, 235/65/17.My thoughts and corrections.
The A/T3W, 235/65/17, max pressure is not 51lbs, that would imply it's an XL load rated tire and it's not.
The A/T4W, 235/65/17, weight seems to be off or it's an XL load rated tire, contrary to the spec sheet, though it's possible that it's heavier because it's no longer a compromised OEM fitment!
That's how it is looking.I wonder if the 235/65-17 Goodyear will be the replacement then for the AT3w?
Damn. I'm due for a whole new set after only 32000 miles. I really liked the balance of onroad manners and offroad chops of the at3w that I don't mind the low mileage. I could probably squeeze another month out of them, but not 2+. They'll probably be racing slicks by April.@Bluebaru the expected release date is end of March, first of April if all goes to plan.
Same! Iām due but torn - canāt imagine making it to April but interested in more details as they come out.Damn. I'm due for a whole new set after only 32000 miles. I really liked the balance of onroad manners and offroad chops of the at3w that I don't mind the low mileage. I could probably squeeze another month out of them, but not 2+. They'll probably be racing slicks by April.
Keep an eye out for some takeoffs that people post or call a local tire shop and see what they have for some used tires. You could get some decent tires for cheap to float you until the the AT4 comes out if that's what you are set on.Damn. I'm due for a whole new set after only 32000 miles. I really liked the balance of onroad manners and offroad chops of the at3w that I don't mind the low mileage. I could probably squeeze another month out of them, but not 2+. They'll probably be racing slicks by April.
