The GVWR doesn't come into play for me nor does a bit rougher ride. or less handling My thing is, I don't want tires that roar on the highway.Assuming they're replacing tires of the same size, that's mostly it.
Don't forget to compare load & speed ratings of each, and remember that you're cutting into your GVWR, ride quality, and handling by 44 pounds of unsprung weight. Maybe none of those are enough make a difference in your case, but if you're already at or near your comfort/safety threshold with any of those, it could be important to you.
I'm not a fan of adding more weight to the tires. I'm very happy with the Wildpeaks that came stock on my BL. I think they have the lowest weight for that type of tire.going with tires that are 11 lbs more each tire over the stock Pirellis?
Harsher ride quality and louder tires. My Pirellis are fine. lolI'm not a fan of adding more weight to the tires. I'm very happy with the Wildpeaks that came stock on my BL. I think they have the lowest weight for that type of tire.
Adding sprung weight to the suspension components will take a toll over time.
Struts, shocks, bushings, etc. MAY wear out quicker. JMO. Maybe my brain housing group overthinking again.
I think you meant "unsprung."Adding sprung weight to the suspension components will take a toll over time.
What's a couple of letters between friends.I think you meant "unsprung."
Not a thing, my man, not a thing.What's a couple of letters between friends.![]()
It'll be harder to catch air? If in the woods you might not be able to outrun the Sasquach.Any other negatives other than MPGS and a few ticks less 0-60 when going with tires that are 11 lbs more each tire over the stock Pirellis?
If I go bigger it will be with these. More of a road tire with a softer compound for better road manners and the sidewall look of an off road tire. I don't do offroading.It'll be harder to catch air? If in the woods you might not be able to outrun the Sasquach.
I think you made a good choice. It is a very reliable tire. We have used it to pull trailers up and down mountains in all sorts of weather. I put them on our 2025 Sasquatch on the second day of ownership.I went from a highway energy conserving tire to the cooper discoverer road and trail at's which are about 11 lbs more than the tires I had on. the only thing I noticed was the loss in fuel milage, I went from 34.5mpg to 31.7mph and that is mountain driving 90% highway averaging about 69mph.
the reason I switched tires is we need the mountain snowflake in the winter as we get good snow storms in the mountain passes, and I was tired of changing tires twice a year. plus, I wanted a tire that was off road capable for checking out new areas to take the truck and camper.
