The GVWR doesn't come into play for me nor does a bit rougher ride. or less handling My thing is, I don't want tires that roar on the highway.Assuming they're replacing tires of the same size, that's mostly it.
Don't forget to compare load & speed ratings of each, and remember that you're cutting into your GVWR, ride quality, and handling by 44 pounds of unsprung weight. Maybe none of those are enough make a difference in your case, but if you're already at or near your comfort/safety threshold with any of those, it could be important to you.
I'm not a fan of adding more weight to the tires. I'm very happy with the Wildpeaks that came stock on my BL. I think they have the lowest weight for that type of tire.going with tires that are 11 lbs more each tire over the stock Pirellis?
Harsher ride quality and louder tires. My Pirellis are fine. lolI'm not a fan of adding more weight to the tires. I'm very happy with the Wildpeaks that came stock on my BL. I think they have the lowest weight for that type of tire.
Adding sprung weight to the suspension components will take a toll over time.
Struts, shocks, bushings, etc. MAY wear out quicker. JMO. Maybe my brain housing group overthinking again.
I think you meant "unsprung."Adding sprung weight to the suspension components will take a toll over time.
What's a couple of letters between friends.I think you meant "unsprung."
Not a thing, my man, not a thing.What's a couple of letters between friends.![]()
It'll be harder to catch air? If in the woods you might not be able to outrun the Sasquach.Any other negatives other than MPGS and a few ticks less 0-60 when going with tires that are 11 lbs more each tire over the stock Pirellis?
If I go bigger it will be with these. More of a road tire with a softer compound for better road manners and the sidewall look of an off road tire. I don't do offroading.It'll be harder to catch air? If in the woods you might not be able to outrun the Sasquach.
