Quashish Family Ride Thread : 2024 Badlands
Quashish
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
Went for a weekend road trip to the coast to break in the new suspension. Rides really well, still feels planted but a bit softer over the rough roads and bumps. But no weird sway or understeer when you want to do some spirited driving. There was a loser in an acura TSX behind me for a bit driving through some twisty roads on highway 128 through berryessa who was kind of riding my ass, but at the same time couldn't stay in the lines, he was driving beyond his skill level, had multiple opportunities to overtake me and couldn't. Pretty funny.
Anyways I threw in this perfect air freshener before the trip.
Any fans of the simpsons?
Quashish
Quashish
Tomas
Sacramento
Added some Chineseum accent lighting.
https://www.amazon.com/dp/B0FDFHN92D/ref=sspa_mb_hqp_detail_mobile_aax_0?ie=UTF8&psc=1&sp_csd=d2lkZ2V0TmFtZT1zcF9ocXBfcGhvbmVfc2hhcmVk
There are other sets with more than just a 4 pack. Which might be a better deal. Since the remotes seem to be specific to the lights they come with.
Not sure when I'll actually use them, but for $10 for a set of 4 ended up buying 2 sets so $20 total not bad at all. I found the small version first then seen they had an "upgraded" version with 4 leds instead of 2 for the same price. So used the 4 led ones for the wheel wells, and the 2 led lights for the engine bay.
I need to do something about the hot spot look of the engine bay ones. Either re-position or scuff up the lenses or something.
I programmed both sets to have the same flashing modes. The red flashing mode matches the rear fog lights when those are on.
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20260411_213333
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands InCollage_20260411_215101797
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20260411_213809
Quashish
Quashish
Tomas
Sacramento
Not much room in the truck area. But here is a bracket I made from some salvaged stainless steel from an old drinking fountain. Rivet nuts to secure quick release mount, and wedged between the seat brackets and the desert does it spacer plates. Tightened back down.
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20260503_145328
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20260503_145340
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20260503_145814
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 20260503_145834
Quashish
Quashish
Tomas
Sacramento
At the supermarket yesterday and noticed the passenger side marker turn signal was burnt out. Ordered a new set and they arrived today. Dressed it up with some expandable sleeving and weather tight ends real quick and swapped them. Back in business. Not too bad the first set lasted about 5 1/2 years. I only changed the passenger side so far since driver side is still fully functional. But will probably swap it also as soon as I get a chance.
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 1000092613
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 1000092614
Quashish
Quashish
Tomas
Sacramento
This is in transit to me now
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 1000093258
No TPMS, question is, if I get a sensor in there, matching tire. Can I do 5 tire rotations? Is anything needed? Some simple TPMS relearn through forscan?
Mine came with a sensor and the car figured it out on its own.
Quashish
Quashish
Tomas
Sacramento
Wheel should've been here yesterday but got delayed.
I did get this little OEM addition
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 1000093365
The garage door remote would take forever to work. Have to hold the button down a few seconds and try 3 or 4 times sometimes. This homelink works the first time. Should've done it sooner!
Quashish
Quashish
Tomas
Sacramento
Spare wheel finally got here today. Definitely different wheel than what was pictured. After washing it and removing some paint transfer still has deep gouges all around the wheel. Return initiated immediately.
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 1000093915
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 1000093914
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 1000093907
Quashish
Quashish
Tomas
Sacramento
Ford Bronco Sport Quashish Family Ride Thread : 2024 Badlands 1000094570
Different spare wheel arrived in much better condition. Still dirty, and had some surface scratches and a couple rock chips. But I cleaned it all up, polished it up, some careful wet sanding on the worst scratches and some more polishing, and a bit of paint touch up. I can't even see the scratches anymore unless I'm inches away looking for them. I think I'll remove the wheel weights before I take it to get a tire mounted. And maybe give it a wax coat after the touch up paint cures a day or two.
