Upset over missing engine cover!
Deleted member 6290
540B is number 4, "Insulator", you dont need to buy this, it's already on the engine, under the wire and pipe rat's nest.
I have tried to buy the white stud, 957A from several sources, all have told me that it has been discontinued. If anybody finds a source or replacement, please post.
Kodiakbear
Kodiakbear
Southern New Hampshire
2021 Bronco Sport Outer Banks
The insulator IS NOT under the wire and pipe rat's nest! It goes over it to keep the freaking foam engine cover from melting all over your engine! The 6a957 long plastic ball mount stud is available, but you might have to accept backorder status (it is available as of 11-15-21), but proceed and it will show up/or at least mine did! When one asks for the "engine cover", be sure to ask for the "engine cover assembly and all related parts to install correctly on my engine". Here is the current weblink... https://parts.ford.com/shop/en/us/fuel-system/fuel-injection-and-pumps/insulator-12018245-1?dealerId=24626&catalogId=251&langId=-1&storeId=1405&krypto=nydXFblgg/RIsamiacPVSgoUCxIhGpQzyyhwGZ/5C32WpJk7mhCUluuFWfMkgINlsHHZLDOpDrBmVHf+vErhrMuQlSmQF7J1Ig8YmxhVHUN1aEQre4RO24pEc2xvtWBVGRgOcAAt2m1Dsm7UlGRFTW47mQvO8kdNXmZOlpvVCLDdMzuOxeFQPphYhVCyEaIh6aKP8RkNgvUe9aGJMYWl+NTvRjRVPrQHAVPXi5+UkRGnxD1q7dIx/ip6CHS+SzIf6cikagZY7G95ebUf97PXmAB4kbu1/VJnlrUzFRVSF54=
As for the white plastic stud, when I had tried to buy it online, at least 3 dealers told me it had been discontinued. This was before it was determined that it is already installed on the engine, so there is no need to order it even though it may become available.
As the original early poster about the missing engine cover, I bought the insulator. It is identical to the pre-installed insulator that is UNDER the wire & pipe rats nest. There is no room to install a second one between the top of the engine and the engine cover. Please back up your statements with pictures of the insulator installed on top of the wires & pipes. I really do think you should read this entire thread, it is quite educational as well as entertaining!
Deleted member 6290
Regrets for my posting incorrect information as to needing the insulator part. Thank you for getting me straight on that! I zoomed into the pics my daughter sent me and see the insulator clearly, and as you clearly know, is already there. Not to mention you bought one and already tried what I mistakenly thought necessary. Regards
Ford Bronco Sport Upset over missing engine cover! Erin's Engine Cover Mounts Missin
RS1
Ralph
Boston
After many unfruitful encounters with Ford Customer Service 800 number and chat, I have determined they are as useless as they are clueless. They sound very sympathetic but can’t resolve anything. My next step is writing to board of directors. (Not engine cover related)
Rgill
Vegas
Las Vegas
2011 Toyota FJ Cruiser
Got mine the other day, no engine cover, probably going to bring that up when I get my first service
What you should do is take it in for its first service, then when you get it back ask what happened to your engine cover that was there before the service! :crackup:
Deleted User 772562
Maria
NJ
2021 Bronco Sport Outer Banks, 2021 Ranger Tremor
This actually did happen to me in a previous vehicle and I did get my engine cover back!
Robins21
Horse Pasture, Virginia
Our Bronco Sport Big Bend 1.5L doesn't have the engine cover either. Doesn't matter to me.
