Adding Tow Hitch
a33maxi
New England
2021 Bronco Sport - sold
Got the Curt hitch installed today. A few notes:
  • The bumper cutout needed to be much taller than Curt's instructions suggest.
  • The hitch blocks one of the mounting holes for the fabric liners on each side, so you need to finagle them back into place.
  • The access holes are just barely big enough to fish the spacers through. You might need to widen out the holes with a file, or just use a bit of force to push them through.
Pics below. I'm still having the wire harness done at the dealer next week.
Ford Bronco Sport Adding Tow Hitch IMG_0913
Ford Bronco Sport Adding Tow Hitch IMG_0914
Ford Bronco Sport Adding Tow Hitch IMG_0915
Ford Bronco Sport Adding Tow Hitch IMG_0917
Ford Bronco Sport Adding Tow Hitch IMG_0918
PersimmonHills
Oklahoma
PersimmonHills
Oklahoma
thanks. I hope to install this weekend. Great to have more input.
Looks great.
Burke
Vermont
Nice job and thanks for the pics and info. . Did you have to lower the exhaust or was there enough room.
Wabarca2
Walter
Has anyone looked into the trailer hitch that u haul sell's it's a bit cheaper I think.
PersimmonHills
Oklahoma
I did. I couldn’t get any response on availability. They can sell it for ½ price when they don’t have any…
Legin2000
Nigel
I ordered a tow bar from U-Haul on March 9th for installation of March 21st. I am still waiting for it to arrive. Called them yesterday and was told there's a 6 to 8 week wait. That doesn't make sense if someone ordered March 1st and got it this week.
In case you're interested, here's the breakdown on cost:
Hitch Installation1$72.00
Wiring Installation1$90.00
Ball Mount (2-1/4" drop, 7-1/2" length)1$19.95
Class III Pin & Clip1$3.49
2" Hitch Ball, 2-3/16" Shank Length1$10.95
Square Tube 2 inch Rec. (Powder Coat)1$174.95
Curt Taillight Converter 592361$49.95
Unlimited Lifetime Warranty1$5.00
Wiring Service Plan1$10.00
Subtotal:$436.29
ogpEz
Es
Los Angeles
2021 Bronco Sport Badlands
Thanks for posting! I was really worried you'd lose clearance adding in your own hitch but it looks like you didn't lose any at all. Where did you get this installed?
a33maxi
New England
Thanks, and yeah it’s pretty comparable to OEM. I got it installed at a local indie shop, they charged me .75 hours labor.
PersimmonHills
Oklahoma
I Installed the Curt hitch. The fit and finish is exceptional.
Overall the instructions are pretty good.
It is a huge help to have help. Pretty awkward alone.
I worked without raising the Bronco. It was easier than having it on stands (but not as easy as it would be on a lift!).
It did take me a bit to realize the horizontal crossbar goes into the plastic facia. The metal shield goes between the hitch and muffler.
i found it easier to fish the empty bolt end of the fish wire through the mounting hole and out the side opening. Then attach bolt (with plate).
The bolts go through the side opening without modification. The trick is to turn them slightly (because the corners of the hex nuts interfere)
alas - I tried to make the facia fit closely and it is too tight. Not a big deal to fix, though
My second time will go easier…
Pete_72
Peter
Louisiana
Honda
I just got a quote from the dealership to install a hitch and wiring harness and it’s over $800! They have never installed one yet so they based their estimated time for labor off an Escape, they said 6.5 hours because of the wiring harness.
PersimmonHills
Oklahoma
Wiring runs from the battery back
Pete_72
Peter
Louisiana
Honda
I was hoping that I wouldn’t have to tackle this install but I don’t think I’m will to pay that much for it.
