do you mind share what you did it?Did they try activating it in the APIM and the IPC?. It only worked when I did that.
21-24 BS are the same. I don't see why not.i would do this if i could. ours is a 24' though. not sure if it would be possible
If it worked on mine, it should work on all those that have a memory mirror.i would do this if i could. ours is a 24' though. not sure if it would be possible
Yes, I take screenshots when I enter with Forscan.do you mind share what you did it?
Our 2024 badlands didn't come with memory mirrors. I wish it had a memory setting for mirrors and drivers seat. But here is how our driver side window switch looks.If it worked on mine, it should work on all those that have a memory mirror.
