Mirrors + tilt down + reverse
rugedraw
Javier
Miami, FL
I didn't get a chance to tinker with it last night, but I will circle back here when I do.
pantera155
Pantera
Argentina
Bronco BADLANDS 2025
The 2025 model has mirrors with memory. I think it could be done in the new model! What Fodscan configuration needs to be changed?
Ford Bronco Sport Mirrors + tilt down + reverse IMG_20251218_010613_923
rugedraw
Javier
Miami, FL
pantera155
Pantera
Argentina
rugedraw
Javier
Miami, FL
I did all that, but the option doesn't appear on the screen. It obviously doesn't work with the Bronco Sport. Thanks!
Really? That's strange. I had the option appear, but it was not able to be turned on.
Stircrazy
BC, Canada
what do you mean by mirrors with memory? My 2023 has power mirror memory that you can tie to your key fob and the three selector buttons.
I imagin you could set the mirrors up for how you want them for reversing (usaly its just the curb side one so you can see the rear tire) and tie that to position 3. the only issue is you have to shift to park briefly to hit the memory button to re-adjust their position. in my truck I can adjust the seat/mirrors while I am driving via the memory buttons, so I wonder if there is a way to allow that in the bronco sports.
pantera155
Pantera
Argentina
Yes, their mirrors also have memory.
I don't know why it's not working.
rugedraw
Javier
Miami, FL
Yes. I don't see anything! Can you show me how it appears for you?
I can't anymore. I swapped out the APIM in ours and I am running Sync 4 now. But when it had the Sync 3 module, the option for reverse tilt mirrors did appear. However, it was grayed out and I was not able to toggle it on/off.
pantera155
Pantera
Argentina
After adding the same thing to the IPC, it works!
Now I just need to activate the automatic folding. (difficult but not impossible).
hefler
Global
Bronco Sport 2023
WOW
@rugedraw and myself tried a lot do to that in my BS Badlands 2023. No success :(
rugedraw
Javier
Miami, FL
Nice! Make a write up of what you did. I will probably follow your lead on this. I don't care about this feature on my F150; don't really need it since my truck has literally 8 cameras . 🤣 However, I would love to add this to our BS.
pantera155
Pantera
Argentina
Did they try activating it in the APIM and the IPC?. It only worked when I did that.
Frenchy906
2025 Bronco Sport Badlands
I second this!
