Bronco Sport Badlands - Lift Options
2025 Badlands Sasquatch
...BUT I'm not sure that's a fair comparison because I believe they changed the wheel well moldings on the new Badlands Sasquatch.
You are right about that; the BLSas does have specific "High Clearance Fender Flares" (Ford's language, not mine) unique to the package.
It's still mostly apples to apples, just more along the lines of Red Delicious to Granny Smith. ;)
incavulator
I'm starting to think we should take measurements to the bottom of the pinch welds front and rear at the jacking points. I was just doing some research on the forum and it looks like someone with a Badlands Sasquatch showed 9" of clearance to the bottom of the fuel tank skid. I've got an honest 10.25" to mine.
Bluebaru
This will of course be affected by the actual diameter of the tires but I have been suggesting this for some time, as the best way to measure lift, when the tires remain the same or total lift when changing the wheels and tires, at the same time.
22 Badlands w/Flatout Coil-overs 2" lift, sitting on 245/70/16 Nokian Outpost nAT's with a theoretical (and actual diameter when measured, off the car, and at 33 psi) diameter of 29.5".
Gas tank skid at 11", bottom of front Pinch weld at 12 5/8", bottom of rear Pinch weld at 13 1/2"
incavulator
Thanks for the feedback and the measurements, Bluebaru!
As close as I can measure, I'm at 10.3" to the bottom of the skid plate. That's with the 245/65/17 AT4Ws. The pinch weld measurements are easier to measure accurately. Those average 11 13/16" at the front, and 12 13/16" at the rear.
Quick math says you're pretty close to 3/4" higher at all locations which makes sense because your lift is 0.5" taller and I'm guessing the rest (?) is attributed to difference in our tires OR just variation between advertised and actual lift measurements.
Appreciate the comparison.
incavulator
Ford Bronco Sport Bronco Sport Badlands - Lift Options IMG_2477
Fronts are in. Not a bad job, two hours start to finish, wish I had started sooner so I could do the rear tonight, but I’m doing them in the morning.
Looks great. I did mine across a couple evenings, too. Had an appointment i had to break for one night.
PS. Did you check the welds for the brackets that the sway bar end links attach to? 😀
Frenchy906
2025 Bronco Sport Badlands
Mine all look solid. That was the first thing I checked after seeing the post the other day lol
Frenchy906
Ford Bronco Sport Bronco Sport Badlands - Lift Options IMG_2493
All done. Camber was spot on afterwards in the front. The rear is 0.1° out of spec on the driver side, perfect on the passenger side, so I’m not messing with it. The toe in front was all wack, but that’s fixed now. Rides so nice.
245/60/17 Falken Wildpeak AT4
TheX
Randy
Austin TX
www.randymcelroy.com
My OBX Sasquatch has them.
Garth
Garth
Ontario
Did you use after market camber bolts?
