Poor Back Up Camera at Night
AndyC362
Andrew
South Carolina
I am not sure if its my camera or of anyone else feels that the back up camera at night is very poor, splotchy looking and hard to see. I suspect it may be related to the light output from the reverse lights not producing enough output for the camera to be effective.
Is anyone else experiencing this and has anyone changed out the reverse lights to brighter bulbs or even LED without error codes?
Thanks!
Thanks!
The Ford backup cameras do not seem very good. Even my full-size Bronco is about the same. My 10 year older Lexus is much better as is my wife’s 6 year older Honda HRV.
it’s a little better when absolutely clean but still not great. Fortunately I’m an old fart and still can backup using mirrors.
2025 Badlands Sasquatch
Compared to the last-gen Souls, the BS camera is studio quality. It’s pulled me away from mirrors more often than not.
Glenn
Alberta
2025 Bronco Sport, 2016 F150 Platinum, 2018 Escape
What is involved in replacing the bulbs? How much of the back end do you have to disassemble? :)
Open the hatch, it’s just two screws and the entire rear light assembly pops out. The bulb holders are standard twist to release.
gstalnaker
Guy
2025 Bronco Big Bend
Before you buy anything, try this (which I learned on the F150 forum when I searched about its too dark backup camera and i found a forum post that lead me to an acceptable solution)
When backing up, you technically don't need your forward lights, so turn them off, manually, with the switch. Don't accept Auto-off here, you have to manually turn the switch to off. This worked for my F150 and it also works for my Bronco Sport. The image on the screen is almost night-and-day in brightness difference.
I park in a condo garage and have to back into the spot because there's a big concrete support column next to my spot. Backing in puts the vehicle between the lights that are along the center of the garage, and the wall behind the spot I'm backing into. Turning off the headlights does the trick.
When you next turn on your Bronco, it will revert to Audo mode, so you don't have to redo that every time as well.
AndyC362
AndyC362
Andrew
South Carolina
Going to try this, I came from a 2021 Tahoe and even with the incandescent back up lights it was night and day compared to the BS. I may also upgrade to the LED lights if this idea doesn't work out.
AndyC362
AndyC362
Andrew
South Carolina
I have no issues with the 360 cams during the day, the back up though just isnt very good at all after dark. I had a 21 Tahoe before this and the difference in cameras was night and day even with the larger screen in the BS.
Yeah, the low-light performance leaves something to be desired. Still, it's better than my Soul was. Better reverse lighting is needed, to be sure.
gstalnaker
Guy
Thanks!
Here's a Dropbox link to a 15 s video of what happens when I turn the lights off manually while in reverse & the camera is on. The freaky flashing is the cell phone camera software adjusting to the brightness change. But I hope you can see there is an overall brightness increase ...
https://www.dropbox.com/scl/fi/05hnksv0nnv1e6n17vide/FordBroncoBackupCamera.mp4?rlkey=w5jm1jqmqr2as65nqrnyf7l73&st=8zzd262k&dl=0
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
been discussed on the forum before but Baja designs has a tow hitch inserted S1 pod light for reversing. sometimes isn't in stock though.
i have a revere boost bar from Morimoto that bolts to the top of the license plate wired to reverse power. rear bumper removal not necessary. i was doing some other wiring at the same time.
Ford Bronco Sport Poor Back Up Camera at Night 49783-fcb0bb56d487b8f8e0b355afcc0cb749
Ford Bronco Sport Poor Back Up Camera at Night 49785-fb645b09030845957b2f7d5500f3a838
Ford Bronco Sport Poor Back Up Camera at Night 49786-17cdc92f1f39e48797072e79ae7b5757
Ford Bronco Sport Poor Back Up Camera at Night 49788-281e4cf4d41e9c986d5bc50ba2874cd3
Ford Bronco Sport Poor Back Up Camera at Night 49789-bc6af96480bec8af0412747025955cdf
Ford Bronco Sport Poor Back Up Camera at Night 49816-678d54c1970cc70c0e02fbbe6af31812
