Running lights won’t turn off in Auto
wiyeti
Corey
BS Outer Banks
Has anyone experienced their daytime running lights not turning off after you park the car and lock it? The lights are in Auto mode and I have to turn dial Off to get them to turn off. Seems like it started with BMS programming a while back.
Curious if anyone has had this issue and found a solution. Thanks.
Ford Bronco Sport Running lights won’t turn off in Auto IMG_2394
Jmuns
2022 Bronco Sport BL
Do you have a 2021 model or early 2022 model? (The same issue may be on some 2021 to at least some 2023 models)
If so there are a few service bulletins to look at: one replaces a defective (from factory) headlamp module switch (the switch on the dash you interact with):
See these posts from me:
look for Post #67 from me if this link does not directly go to my post #67:
https://www.broncosportforum.com/forum/threads/part-of-headlight-staying-on.2926/post-210767
https://www.broncosportforum.com/forum/threads/daytime-running-lights-sometimes-stay-on-after-shutdown.4418/post-217247
Stircrazy
BC, Canada
when you shut it off and lock it they are now courtesy lights and will stay on for a minuet or two.
wiyeti
wiyeti
Corey
BS Outer Banks
Thank you. 2021 OB so I’ll take a look. Appreciate you!
