Chiefthepup
Colt
Washington
Installed the rest of the Yucca roof rack today. Original shipment was missing the 2 rear side panels. Ordered on 08/18, delivered on 10/09, missing panels delivered 10/16. All that to say, when you order be patient. They were awesome to work with and the build quality is absolutely phenomenal. 10/10 would recommend even with the wait time. Also it can definitely be installed with one person. I put cardboard on the roof to protect the paint and set it down from the side of the vehicle than positioned the foot brackets.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5428
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5433
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5434
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5432
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_5431
That looks awesome, Colt! Thanks for sharing that on the forum.
Frosty
Dennis
Tapped the wrong tab & deleted my AGM battery change over from awhile back.
Sometimes technology baffles me! ?
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_3626
Replaced the OEM jacketed lug nuts with a set of Dorman OE FIX one-piece nuts.
just what I am looking for but is this the part # for the lug nut in your pic?
Dorman 611-303CD 5 Pack (OE FIX) Steel Wheel Nut M12-1.50 Capped, Length: 19mm Hex, 32.1mm (1.26”), Width: 26.5mm; Color: Chrome; Wheel Nut Style: Dometop Capped Nut; Thread Direction: Clockwise (Right); Thread Type: Fine, OE Replacement Or Custom Performance: Verify lug nut to wheel mating surface for proper and safe fitment $12.84 https://a.co/d/3vS6UpH
davidg4781
Replaced the OEM jacketed lug nuts with a set of Dorman OE FIX one-piece nuts. Great look and fit and less worries about rusty nuts.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_3057
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_3053
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_3049
Are the ones on the wheel all replacements? Or a mix? Those look nice. I looked at others and they stood out some. I'm getting a tire rotation soon so this might be a good time to swap them out.
jazzdab
Thom
Raleigh, NC
Yes, 611-303CD is the part number. I went to the Dorman site to confirm compatibility before ordering from Amazon.
jazzdab
Thom
Raleigh, NC
I posted that picture for comparison. The OEMs at 5 o'clock and 10 o'clock are more satin while the Dormans are slightly shinier and a bit more pointy. But it is very close. So close I used masking tape to mark each lug until I had changed and torqued each nut.
