Mystery white powder coming out of hood
Dennis Kilbride
Dennis
Minnesota
Take a look. See what you think it could be. Seemed to get wet and then leak down from inside hood?
Ford Bronco Sport Mystery white powder coming out of hood bronco sport mystery white powder
Paradocks
Doug
Pittsburgh, PA
2025 Bronco Sport Badlands
I think the rain and wind force gets the tetralubisol on the hood latch wet and that is the runoff. Every now and then it's a good idea to re-treat the hinges and latches on the doors and such.
davidg4781
I'm having a hard time finding tetralubisol at the local AutoZone. What else can we use? I have lithium spray grease and silicone spray.
What about the rubber gaskets? I used to put Shin-itsu grease on my Accord.
I use the lithium spray on some of the parts. Somewhere I have an actual stick of door lube. It's like a giant chapstick/glue stick made for car door latches. I bet Ford parts counter has an official product. Not that I endorse Ford parts, but you can find out what it is and then buy the same thing at the regular store or compare the price. Ford is pretty decent price on some stuff.
kshaw
Kent
Gaithersburg, MD
If you are detailing your engine, avoid using Simple Green or similar. It will cause white powder on your aluminum parts. That is corrosion. If you want to use Simple Green, get the NASCAR or Aviation version which is not corrosive.
Elegance
Kris
Call me crazy, but it kind of looks like what happens when we have a severe storm here in NC and the pollen just gets blasted off the trees. Pollen mixes with rain, often sideways rain, and trickles into my gas cap and under my hood. There are streaks of watery pollen in all the nooks and crannies from some wild storms we've had this week.
Dennis Kilbride
Dennis Kilbride
Dennis
Minnesota
It's all over under the hood. I checked the grill...nothing. I saved a sample.
Ford Bronco Sport Mystery white powder coming out of hood DSC00474pm
Ford Bronco Sport Mystery white powder coming out of hood mystery white residu
Ford Bronco Sport Mystery white powder coming out of hood DSC00479pm
Clean it off. Then keep an eye on it through the summer to see if it reappears.
davidg4781
I forgot if I asked here or somewhere else, but I was looking for a good wheel and tire cleaner a while back. I tried a couple and one from Meguiar's worked really well.
I noticed Ford sells a wheel and tire cleaner that's about 1/3 of the cost. I'm going to pick some up and see how that works. 1/3 is pretty decent price!
