Moonroof exploded
Nope. There was no one anywhere near
Me.
Yes but how could you be sure something didn’t hit the moonroof at a point in time in the past without any apparent damage at that point in time and for whatever reason (bump, colder weather, hotter weather, etc) later in time at the moment you noticed the moonroof exploded for no reason?
But in any case I agree with you that Ford should cover that under warranty - Ford could not prove the moonroof did not explode for no reason just as you stated… do you plan to elevate the issue with Ford and to continue pursuing the fix to be made under warranty?
I do not believe you are the first this has happened to.
RCO302
Roy
I have elevated it to Ford. They say they can’t override the determination of the local service department. Funny, the local service department made their initial determination without even looking at the vehicle.
Jmuns
2022 Bronco Sport BL
That’s wild! Glad you’re ok
Ok. Did you next try to reach the Ford Regional Manager (the regional rep) for your area? You have a pretty strong case but I suppose Ford could see it as no evidence the moonroof self exploded.
Also was most of the moonroof glass shot up and away from your BS or did nearly all glass fall inside?
RCO302
Roy
The glass did not break further until after I stopped and got those pictures. Then it began to crackle. It fully cracked up the whole glass but did not collapse. I had to press it out in order to be able to drive away. It basically fell apart at that point, except along the trim where it is still fully adhered.
RCO302
Roy
How do I find out who the Regional rep is for my area?
I am 99% sure a service manager at your local dealership can tell you the name and phone number of the regional rep for your area
I see the pics you posted now … with those pics and some reasonable idea of the temperature, humidity, location, speed of the vehicle, and other pertinent facts at the time of occurrence can be provided to the regional rep to evaluate your case
RCO302
Roy
Oooo. I’ll try that. They’re not going to like it.
Broncoette
Be Kind
Planet Nice
Hello! Send us a private message with your VIN and current mileage. Allow me to see what I can do to assist. Thanks!
I sent you a message; did you get it?
Ford Motor Company response is simply someone monitoring social media accounts. I don't know how much help they will actually give you.
RushMan
Russ
NW NJ
'24 Shadow Black Badlands
