dakman
Used Dakman’s hood shake mitigation solution yesterday (¼ inch diameter flexible plastic gas line inserted into hood gaskets) and it significantly reduced vibration and hood shake. 6’ is exactly the right length.
To give credit where it is due, I got this info from member Canuck in the thread titled " Hood Vibration Flapping Bouncing".
Having to reinforce the rubber insulation on a few of these replies leads me to think the rubber bumper stops are not adjusted properly. One response here mentioned this.
My 2023 has the front bug deflector, and did not before or after this install have the vibration/flapping/bouncing hood syndrome; not at any speed (legal speed limits).
davidg4781
I don't think I have the flapping hood issue either. I was on the road doing 75 mph for over an hour and never noticed anything.
I wonder if there where so many complaints that Ford did some assembly line corrections to the hood install/adjustment?
sinbuster007
Brian
Hagerstown, MD
2 SUV's, 2 Mustangs
Quick clean and some decals…
Seen and unseen
Ford Bronco Sport What did you do TO your Bronco Sport today? A8075278-A1A9-428B-8CBF-437448740F20
Ford Bronco Sport What did you do TO your Bronco Sport today? C71C723A-5EF5-4616-8E23-FAE619F97E30
Ford Bronco Sport What did you do TO your Bronco Sport today? 65043023-2DAA-4384-9712-E9FF3B21AD19
Deleted member 6350
Changed my oil on my 2023 OBX with 1.5 and it now takes 6.6 quarts of oil with filter change, also has a plastic oil pan.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2178
CrazyKZ
Ken
Allen, TX
Did Some cleaning and installing Morimoto lights and whf antenna
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0519
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_0518
Who installed the nudge bar? Any problems keeping the hooks with it? I’ve got the same set up and it took awhile to find someone who would/could do it.
RushMan
Russ
NW NJ
'24 Shadow Black Badlands
Installed EGR side window deflectors.
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2167
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2168
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_2169
Any particular reason why you chose EGR over other brands? TIA
[I'm not affiliated with any manufacturer or distributor of these products]
Rhel
Rögnvaldur
Iceland
www.facebook.com
Hi I did install it . Well no not so much just cutting the bracket around the hooks that’s all
its ok to cutting the bracket its only for lights not towing the hooks are made for towing
CrazyKZ
Ken
Allen, TX
Nice job!
Deleted member 6350
I’ve always had good luck with EGR, I didn't want stick on’s, partial to brand loyalty I guess.
