Largest tire size on 2021 BS Big Bend -- with and without lift kit?
kyle.miller_07
Kyle
Gainesville, FL
Wife wants bigger tires on her ‘21 BS Big Bend.
What’s the largest size it can manage? And what if I put a 1.5-2” lift on it?
Thanks a ton!
245/65r17 is the largest tire you can fit without doing modifications to the frame. Lift doesn’t help change that.
Actually 235/70/17 Goodyear wrangler at 30.2 inch fit my first edition no rub at all .
Ford Bronco Sport Largest tire size on 2021 BS Big Bend -- with and without lift kit? 47DA4262-C2B8-4491-84DA-556A6EED077B
Ford Bronco Sport Largest tire size on 2021 BS Big Bend -- with and without lift kit? A0BA61CF-A9E7-4C6F-93FC-5C58FD0AD24B
Ford Bronco Sport Largest tire size on 2021 BS Big Bend -- with and without lift kit? E1F5B57D-8011-4D17-B1C3-3DBEBA7C1690
GoatsyBanks
Josh
New Hampshire
And you got EZ Flares. I'm back and fourth on that. Don't want to pay $400 for the full set.
Reactions: Jrl
GoatsyBanks
Josh
New Hampshire
https://www.tacomaworld.com/tirecalc?tires=245-65r17-235-70r17
guess it depends on your definition of bigger. It’s skinnier. There’s also limited options In that size for what it’s worth as well.
I'm running 245/65's.
One reason I'm thinking of doing 235/70 is for such a light vehicle I have hydroplaned and been floating on snow. The tires are rated to be great at preventing it too. Definitely going to loose some of the wide stance look though
Actually they are the same 235 size that I had on my original set , they will cut the snow and rain a little better than 245 . Less contact with ground , give that a little thought. Simple math .Enjoy
endrMinr
'21 Bronco Sport
I swapped my falkens for cooper discoverer at3 on same wheel, and went with higher aspect ratio of 235/70r17. Bigger XL-rated tire with more sidewall for all my offroading needs. These are well-siped and 3 peak rated, excellent reviews, I've never had an issue in rain, snow, or mud.
nicolasmj8
Nicolas
San Diego
I’ve got Toyo open country at3 265/65R17 on mine with a 1.5” lift and minor trimming. They look great and ride great too, both on and off-road.
Hot Rod Mike
Rocklin Ca.
Gladiator , Wrangler , Bronco
Falken wildpeak 235/65r17. It’s the lightest tire at 31.1 lbs. The best all round tire for SPORTS
Marinaguy
New York
245/65/17 KO2's on my Big Bend. No issues. Speedo averages 2mph difference at highway speeds. No issues with the 1.5l turning them either. I wouldn't take it to a drag strip, but I wouldn't have done that with the stock tires anyway.
Ford Bronco Sport Largest tire size on 2021 BS Big Bend -- with and without lift kit? 20230331_074109
GoatsyBanks
Josh
New Hampshire
So no rubbing at full lock with that size?
have 245/65 cooper's now.
235/70/17 Goodyear wrangler also no issues to date. And that is on a factory lift First Edition stock BS .No lift needed..
Ford Bronco Sport Largest tire size on 2021 BS Big Bend -- with and without lift kit? EE92BB16-4761-43E3-9468-CCB5A189B6B3
Ford Bronco Sport Largest tire size on 2021 BS Big Bend -- with and without lift kit? F6A607EB-7EF1-45EF-8B3B-1A2B804B629A
I would say if you are base , big bend , outer banks. Then I would not go above 245/65/17 (without a lift). I would read Eric (meanderthal post dedicated to this in-depth. He is the professor on this subject.
