Bed rest BS best practices
MAGPLM
Maple Grove, MN
2022 Bronco Sport Badlands & 2023 Maverick AWD FX4
Yes, just open hood and plug in. Or have a cord come out an opening in the front end.
magicbus
Nantucket
Rivian R1T, Volvo XC90 Hybrid
The picture shows attaching the negative to the terminal ... is this necessary with the trickle charger? Vs attaching it to the frame mounted charging post?
As Meanderthal mentioned, there is apparently a charge tracking sensor on the battery cable that won’t detect the charge amount if the frame ground is used. There is a video on this forum that brought this to people’s attention.
Well it can (from internal resistance) but far more slowly and yep I missed the part about disconnecting the negative terminal.
Yes, you are correct technically it can still drain, but it would not be from vehicle electronics. It would be the same as a battery sitting on shelf can discharge.
I read once that storing a brand new battery on the shelf should hold a charge as long as two years, with some diminishing over time. So 6 weeks is nothing for the tough (but low cost) bronco sport batteries Ford uses.
MAGPLM
Maple Grove, MN
I say more like a year sitting at a nice toasty room temp at parts store. Not real world outdoors with cold, wind, rain, etc. LoL
SWUKU
SWUKU
GB
KY
Ordered the Noco Genius from Amazon. Due Wed 2/15.
Now I just have to find someone to install it.
Thanks for the advice!
MagicBus, please explain why disconnecting the Positive terminal is dangerous.
I find my BS Badlands won't keep fully charged in the winter with the mostly short drives I do. I notice, because the Auto Stop/Start quits working. I put a trickle charger on it overnight every couple of weeks. RV owners use a battery disconnect switch and leave their batteries on the trailer for the winter with no issues. If you store your BS outside, a $20 solar panel on your dash that plugs into the cigarette lighter will improve your battery life. O.K. maybe it is now $30 with Bidenflation.
magicbus
Nantucket
Because it is so easy to bump your 10mm tool of choice against either the chassis or the NEG terminal. Battery safety dictates removing the NEG first. Since we are just doing a disconnect and not a removal, removing the NEG completes the job.
SWUKU
SWUKU
GB
KY
Update: Per peer advice on this forum, I followed the links in this thread and purchased:
Ford Bronco Sport Bed rest BS best practices Screenshot_20230225_095441
I managed to drag the 5-minute install out to 20-minutes (LoL).
Pic below
Ford Bronco Sport Bed rest BS best practices 20230220_132421
I secured the mounting bracket via thick Zip Ties (supplemented by velcro wraps) instead of the supplied metal screws b/c I didn't want to drill holes in my BSFE w/ 2.0L engine, and concerns about dissimilar metals tendency to corrode.
After 3-weeks of inactivity, the battery charge was <75% but the Noco got it back to +/- 100% overnight, as indicated by the green light.
I won't be able to drive it for several weeks, but plan to check the zip-tie install regularly as it allows slight side-to-side movement.
Update: Per peer advice on this forum, I followed the links in this thread and …
Did you connect directly to the 12V Battery red terminal or to the other side of the mounted current detector?
SWUKU
SWUKU
GB
KY
The side one. I couldn't get it to the main one. But it's still under the red plastic cover.
Sounds good.. connecting to the incoming side of the current shunt will allow the BMS to keep track of the trickle charge current added to your battery
SWUKU
SWUKU
GB
KY
Is this the correct mount?
Ford Bronco Sport Bed rest BS best practices 20230225_113443
