Raptor grill accent lights
GoatsyBanks
GoatsyBanks
Josh
New Hampshire
Thanks, red wire to the fuse then black wire to ground ?
Ford Bronco Sport Raptor grill accent lights 23B54F12-40B2-4F3B-868B-E5C160071C88
Yup. I think I grounded them to where the battery grounds to the body.
Snaking the wire under the dash was fun. Lol. There is an opening to go through the center
Thanks ; then you broke the hot with a switch , yes or the ground with a switch ? Thanks Josh Done
Ford Bronco Sport Raptor grill accent lights 88B4704E-D6DC-4094-A84C-1FFC9E7100C7
PonyDriver43
Roger
NE FLA
Recommend test one before you commit wiring. Depends on who made the light. I’ve gotten them from Amazon (China) that power OR ground can be black/red/white.
Reactions: Jrl
GoatsyBanks
GoatsyBanks
Josh
New Hampshire
The hot. Brought the wire from the fuse to the drivers side then through a rubber gromet on the door frame and into the engine bay.
Thanks got it. (
Ford Bronco Sport Raptor grill accent lights 826B53D6-29C0-4D81-84E7-845B75027558
Done thank you)
CrazyKZ
Ken
Allen, TX
@GoatsyBanks
Ford Bronco Sport Raptor grill accent lights 2D57BCAE-EF57-4306-922D-5E4E1314EAA0
All hooked up and working. I’m Loving the Raptor trim lights!
This is the first picture I've seen where the nudge bar can be used with lights as to not interview with the 360+ radar. Is that the Rough Country Nudge bar?
Pmk1710
Peter
Yep, no interference at all.Yes, this is the RC Nudge Bar.
originally was supposed to receive DRL ready Light Bar/Nudge Bar combo (which would also not interfere with 360+) but the DRL light bar was on back order for 5 weeks. I had just purchased my BS and eager to pack out, so I wasn’t going to wait that long.
I ended up getting the light bar that was not DRL, and will eventually mount that to my roof basket, but I found these 7 inch 3 way lights that were perfect for the nudge bar.
Just required a little mounting bracket adjustments, but they work great
Wolf256
Jane
Kingston, WA
2023 Bronco Sport Atlas Blue
So, I bought some lights, but I have no idea if where I would like to put them is feasible. The picture shows where I would like for them to be. Input anyone?
Ford Bronco Sport Raptor grill accent lights IMG_0132
This is what I did .
Ford Bronco Sport Raptor grill accent lights IMG_1107
Ford Bronco Sport Raptor grill accent lights IMG_0833
Can you tell me what lights those are or give me a link?
Sure thing .Thant’s actually my car in their add . Good company and the best quality .I bought the tinted ones to match my grill.
AHerdOfMoose
Denver
Yessir! There is very little wire to work with but it wasn’t too hard. And just to save everyone time, hot is the blue/lavender wire.
I have a potentially dumb question; if you wanted the lights on all the time (whenever the car is on) could you just connect the power wire to the positive terminal on the battery and the connect the ground wire to the grounding spot in the engine bay? Or would this cause a bad/negative strain on the battery?
madfella
El Paso
Not a dumb question…but no. You need power from a source that would be switched on with the vehicle. If you powered it straight from the battery with no switch the lights will stay on even if the vehicle is off.
