2023 Climate Controls
GOAT Mode
PA
'23 Bronco Sport Big Bend
Apparently, the digital temperature display has been removed from the temperature control knob in newer Sports. Can it be assumed, or can anyone confirm that the temperature will now display on the 8" touchscreen?
Ford Bronco Sport 2023 Climate Controls 2021-ford-bronco-sport-9
Ford Bronco Sport 2023 Climate Controls 2022-ford-bronco-sport-big-bend-carbonized-gray-metallic-22
jason202
Jason
Washington, DC
2023 Bronco Sport Badlands, 2009 Volvo C30 T5
Is it pretty safe to assume that the 2023 models won't have the temp display on the knobs either? I don't recall if there was any mention of it in the 2023 order guide, one way or the other.
GOAT Mode
GOAT Mode
PA
That seems to be true. No temp display on the knobs. The temp(s) will display on the 8" touchscreen.
I looked through the MY23 Order Guide and also found no mention of this. Wonder what other surprises we are in for.........
My '16 F150 is like that no display on knobs but selected temp is displayed on touch screen.
It was already in place for 2022 so no reason to list in the 2023 guide. They don’t seem to list all the little things like the passenger insulation panel, cup holders ambient lighting, folding head rests……that seem to disappear as if by magic between model years.
Deleted member 8941
The Maverick did the same thing around May 2022 builds. Mine was built in January so it has the digital temperature display. This is in response to the semiconductor chip shortage. I guess it requires less chips to operate that digital readout and is replaced by a simpler thermostat icon.
BroncoDave
Dave
South Carolina
I believe that the second picture is of the climate control for a Non-Premium Package Bronco Sport. It does not show dual climate control, nor does it show heated steering wheel.
GOAT Mode
GOAT Mode
PA
Thank you. I did a quick Google search to find some images to help illustrate my point. I’m just assuming the knobs will be similar in the 2023.
cgparsons1983
Chris
Boise, Idaho
I actually find the digital displays to look a little tacky. Don't get me wrong, I'd like to have that feature if they improved the look of it, but as it is on the '21 models, I'd rather just have it display the temp when I adjust it on the touch screen like it does with my '22.
PaulOinMA
Paul
MA
This was already and done on Escapes. FE and BS are same from middle-center dash to storage bin. The '20 and '22 FEs I test drove had temperature display on the knobs. PIctured in the '20 Escape brochure.
The knobs on my '22 FE delivered in May don't show temperature. It's on the 8" screen.
It is slight decontenting. Can also be argued that It's safer looking at the top of the screen for temperature rather than lower dash. Keeps you looking out windshield.
sinbuster007
Brian
Hagerstown, MD
2 SUV's, 2 Mustangs
i will have to play with them once i get it. sounds similar to my 15 mustang where its in the digital screen in the center console. i dont tough it much because i mostly keep it on LO no matter what.
in my edge same thing....in the center screen. i set it LO in summer (mostly a/c) and in winter at 68 (enough to get frost of windows, unless its a heavy, or snow) i use the remote start in winter to kick on the driver heated seat and steering wheel then once i get in i turn all that off. its just warm enough for me to be comfortable. i have an 8min drive to work and back .... if kids or someone else in the car they can adjust but its not a burden. i drove the 1.5l when they first came out but never had a chance to drive the 2.0 (bronco version) yet. our escape has the 2.0 so i know what its capable of. i will need to get used to the dash and where everything is.
wife is taking the Edge ST. she doesnt want a new car to drive....so she is giving me the bronco :)
she just has to get used to the Edge ST and all that Power....
now if i could get the ST power in that BS BL...well that would be another story....
This is correct. In the earlier non-premium package cars (first half of 2021?) however, the right knob is the same as the left knob in cars with the premium package, i.e. they had the temp display in the knob.
Jill
Gillian
Oakville, Ontario
Ambient lighting was only ever available on Outer Banks, unfortunately. I miss it having had it on my previous three Fords.
