What's up with the light up numbers on the side of my door?
coopny
NY
2023 BS BL
Yes. Well. Mostly yes. Maybe 90% yes. It tells you exactly how to get the code, but the visual that goes with it is obscenely wrong. At least, it is wrong in my 2021 book. The pad to put the key on is under the rubber mat by the 12v port in the phone cubby, not in the console as demonstrated. Putting it in the console will do nothing to display the code.
Not only are there likely editing error omissions in some versions of the manual like you pointed out, the manual often omits things entirely. If you have two already programmed keys and want to self program additional keys, according to the manual you're S.O.L. and need to ask the dealer to pretty please program keys for hundreds in labor, when in reality there's a self programming procedure that isn't listed in any edition (2021/2022/2023) of the manual. If I had "trusted the manual" I would have been out $175 in labor to add two intelligent access (prox) keyfobs I purchased for less than $100 each - and most dealers wanted $300-$400 a keyfob + labor per keyfob to program, rather than letting me bring my own.
Another example - he dealer I got my 23 BS BL from this time left the barcode/tags that has the backup key cutting (required to get the emergency metal laser cut blade cut without a key to clone) on the keyring, whereas most other Ford Dealers I've encountered have removed it. I don't think it's out of malice, it's just confusing that a barcode is hanging from the keyring with no obvious purpose. Similarly, dealers may not explain the Securicode keypad to new buyers. I was basically allowed to check the vehicle out on my own when I picked up with no walkaround or explanation. I was fine with that having done a lot of research but not everyone is going to be familiarized on all features of the vehicle at the dealership.
I get encouraging people to read the manual to learn about features of the vehicle that aren't obvious in presence or operation, but when someone has a specific question, I don't get some of the replies telling people to "RTM" ... even if the intention is friendly, it comes off as standoffish. At least tell people what to look up rather than just that the Owner's manual is a fount of knowledge.
I'll end my diatribe with the tale of another automaker, circa a decade ago, where I did RTM...: I was working in the larger detroit area at a time, driving for an hour each way to and from a customer to my hotel. I received a 2013 Dodge Dart as a rental, and it was the drive that cruise control was invented for on the highway. I couldn't figure it out. Eventually, I admitted defeat and reached into the glovebox of my Hertz rental to find out that apparently, in 2013, where the Dodge dart was a brand new car with a full digital screen gauge cluster many years before many luxury cars, that cruise control was an option and my steering wheel had blank plastic where the buttons should be... the manual there did teach me that it wasn't ignorance on my end, just a lack of equipment. But that was a decade ago, when Ford also accurately disclosed on-board programming procedures for their vehicles correctly in the manual rather than omitting them.
sajohnson
Sherman
MIDDLETOWN, MD
I liked your entire post, and particularly the paragraph above.
That could save people a lot of money.
Tigger
Tigger
Illinois
I then went home, and placed the owners manual in the library (a.k.a. bathroom) for reading material.
I put the manual in the bathroom too! But I didn’t think to use it for reading. :inspect:
  • Haha
Reactions: MJE
Wazzat
Kent
2023 Ford Bronco Sport
Have you read the manual lol
Just catching up on old posts!
  • Do not set a code that uses five of the same number.
  • Do not use five numbers in sequential order
Wazzat
Kent
If you have two keys, you can program a third, fourth, etc so you can keep an extra key in the kitchen drawer (and plan ahead of time). But if you only have one key, it means a trip to the dealership to buy another one, and pay to have both programmed. Tough nut to bust, but buying an extra FOB ahead of time is cheap insurance.
Wazzat
Kent
If anyone on this thread knows how to raise the trunk on a Town Car, Grand Marquis, or Crown Victoria, and find the little white sticker on the left hinge with the 5 digit keyless entry code on it - then you’re as old as I am, and worked at a dealership!!!
davidg4781
Where did you buy those $100 key fobs from?
And I hope I didn't throw away that barcode. I can't remember what was on my key. I do have another key in a manila envelope that I never opened. I'm honestly not sure where it is. It's been a long couple of months.
CancunBadlands
CancunBadlands
Cancun, MX
You can lock and unlock your BS with that Door Code, it comes handy when you are at the beach, you can lock your BS with the key inside and go to enjoy the #BeachLife #cancunbadlands
Welcome to 1980, that's how long it's been since Ford introduced the security code feature.
DWG
2019 Edge, 2024 Bronco Sport Badlands
May have already been mentioned here but I didn't read through the entire thread. unfortunately the door panel built in key pad has been deleted for 2024. Not just the Bronco Sport but other models too. Replaced with a dealer add on from what I can tell looks like a stick on key pad. I thought the door panel key pad was a great feature.
rootdoc
Peter
South Carolina
Yep. I like the built in keypad much better than the raised stick on keypads.
SLJ
Elbridge NY, USA
Bronco Sport OB, Maverick 2.0 XLT
Hope you're battery does not die on you when out on a hike!
Been using these for almost 20 years and its never happened.
RushMan
Russ
NW NJ
'24 Shadow Black Badlands
I have a '24 Badlands with the dealer installed keypad, ordered from the factory with my car order . It is not a stick on. It is identical to the factory installed keypad on earlier models.
However, the Ford Accessories keypad may be the stick-on item.
Are the digits orange or blue? The top pic is from the Ford Accessories website. The bottom pic is what the factory-installed version on earlier MYs looks like.
https://accessories.ford.com/2024-bronco-sport-illuminated-keyless-entry-keypad-m1pz14a626ab
Ford Bronco Sport What's up with the light up numbers on the side of my door? {filename}
Ford Bronco Sport What's up with the light up numbers on the side of my door? imag
