MIHeritage
Cabe
MI
did you have the front windows done also? i wanted to do 30%on all and 65% on the windscreen. but wife wanted to go a little lighter in the front.
Front windows were done as well, all except windshield. 35% all the way around!. Wanted the same, a little lighter in the front!
BubbaKahuna
Jeff
Jefferson WI
2024 Ford Bronco Sport Heritage
Probably the most subtle 'mod' today - if you want to call it that.
I added the Temu organizer 3-piece set for the console & dash behind the touchscreen.
Console without, then with the tray.
Fits perfectly, easy to lift out & makes getting stuff in & out much easier.
'Hidden' (well, kinda) compartment in the lid of the console.
Fits really well but magnets that hold it shut aren't very strong.
I'll probably put some stronger ones in there or maybe a little Velcro dot or something.
Tray that sits behind the touchscreen on the dash.
Doesn't fit seamlessly, but not so bad that I'll be bothered by it.
If it ever does bother me I'll just remove it, the gel adhesive is strong but can be pulled off with a little heat applied.
All 3 pieces come with little grippy rubber mats that fit in each compartment.
Should hold stuff where they're put just fine & they pull right out for cleaning.
All 3 pieces cost about $30 from Temu delivered. Took about a week to get to Wisconsin.
Ford Bronco Sport What did you do TO your Bronco Sport today? 20250214_162511
Ford Bronco Sport What did you do TO your Bronco Sport today? 20250214_162517
Ford Bronco Sport What did you do TO your Bronco Sport today? 20250214_162537
Ford Bronco Sport What did you do TO your Bronco Sport today? 20250214_162532
Ford Bronco Sport What did you do TO your Bronco Sport today? 20250214_162449
RushMan
Russ
NW NJ
'24 Shadow Black Badlands
I added Drawer Pulls to my console tray. It's a bit difficult to remove the tray to access the lower area when filled up with junque!
https://www.broncosportforum.com/forum/threads/what’s-your-favourite-non-ford-part-you’ve-added-to-your-bs.8572/post-202858
Installed LED turn signal bulbs …
Thank you for doing the Turn Signal LED bulb comparison and posting comparison pics.
updated with info from RushMan:
OE: Rear turn signal lamp.
Specification: WY16W
Power (Watt): 16
“CANbus error-free”
All specifications below are best effort info, please verify any info of interest.
LEDPerf:
T15 bulb 916NA WY16W 16 Leds CREE - Ultra Powerful - Orange
Part #: TBD
Color: Orange
Lumens: 1600
Watts per bulb: TBD
Cost: $27.48 each
Radiation angle: 310°
Dimensions: 47mm L x 14mm W
“https://www.ledperf.us/t15-bulb-916na-wy16w-16-leds-cree-ultra-powerful-orange-p-30346.html
“on-board computer (OBC) error-free LEDs”
“https://www.ledperf.us/leds-and-kits-for-ford-=c=-985_3782.html
LASFIT 194 168 T10 2825 W5W LED Bulb Canbus Error Free, Non-Polarity 400LM
Part #: LX001-T10/194A
Color: Amber Yellow 3000k
Lumens: 400
Watts per bulb: TBD
Cost: $10 less 10% (pack of 2)
“https://www.amazon.com/gp/product/B07B9WHXVY/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Notes: ?? Others used Lasfit 921, Amazon in Amber
Alla Lighting T15 Base 912 921 LED Bulbs, Amber Yellow Turn Signal
Part #: Alla-921-4014-48Y-Yellow
Color: Amber Yellow TBDk
Lumens: TBD
Watts per bulb: 6.5 ??
Cost: $17 (pack of 2)
“https://www.amazon.com/gp/product/B07K1626VQ/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Notes: “possibly too bright”
Also see:
“https://a.co/d/4LDvMxy
Alopee 922 912:
LED Bulb Amber Yellow Turn Signal Bulbs Non Polarity Canbus Error Free W16W LED
Part #: 921 912 T10 T15 ( 12V-18V )
Color: Amber Yellow 6500k
Lumens: 800
Watts per bulb: 4.5
Cost: $12 (pack of 4)
Length: 40mm (1.57")
Diameter: 15mm (0.59")
“https://www.amazon.com/gp/product/B06Y2GQP23/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Notes: @RushMan installed the Alopee turn signal LEDs
Also see:
“https://a.co/d/4x83HAb
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_3474
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_3473
Ford Bronco Sport What did you do TO your Bronco Sport today? IMG_3472
RushMan
Russ
NW NJ
OE Specification: WY16W
OE Power (Watt): 16
@RushMan do you still have the part numbers handy for these 4 that you compared? I’m looking up some of their specs.
LEDPerf:
Part #: TBD
Color: TBD
Lumens: TBD
Watts per bulb: TBD
Cost: TBD
None listed for Bronco Sport?
Lasfit 194:
Part #: TBD
Color: TBD
Lumens: TBD
Watts per bulb: TBD
Cost: TBD
“CANbus error-free”
Alla 912:
Part #: TBD
Lumens: 2000
Watts per bulb: TBD
Cost: $12 (pack of 2)
“CANbus error-free”
Alopee 912:
Part #: TBD
Color: Amber Yellow 6500k ??
Lumens: TBD
Watts per bulb: 4.5 ??
“CANbus error-free”
Notes: @RushMan installed these
I've misplaced the original bulbs and packaging, but was able to find the links to the Amazon pages.
Manufacturer Part Number ‎Alla-921-4014-48Y-Yellow
Item model number LX001-T10/194A
Alopee 922 LED Bulb Amber Yellow Turn Signal Bulbs Non Polarity Canbus Error Free W16W LED
Item model number ‎921 912 T10 T15 ( 12V-18V )
LEDPerf
No part number, just a description on my receipt.
LEDPerf
Thank you !! Very useful info. I used your info and updated my prior post… thanks!!
Colonel Angus
Dean
New York
Eibach 1.7/2.0” lift springs came in this week! Hoping to drop it off to have them installed soon. Will post before and after pics.?
Can't wait to see the results. Thinking of doing the same this Spring.
bronco68halfcab
Stephen
Clarksville,TN
'68 Bronco, '78 Granada, '11 F150, '24 BS
I installed a new set of wiper blades this morning. The first on took some time figuring out the new to me wiper blade lock system. The second one took seconds to install. I don't want to sound like an old man but every time I get a different vehicle it seems to have a different kind of wiper blade retention design. I'm starting to take it personally.
Quashish
Tomas
Sacramento
2024 Bronco Sport Badlands
I had bought some Bosch wipers for my sister in laws car a 2021 jetta and the instructions were terrible. And about 3 of the ends you clip on look very similar. After struggling to make the correct one fit for a minute, then trying the wrong one, went back to the first and it popped right in. Second one was a breeze. I'm sure I'll forget when I go back to Change them again
Quashish
Tomas
Sacramento
Took apart the driver door panel just enough to get a peek to see if the harness for illuminated keyless entry pad is present. One thing our big bend had that this badlands doesn't, (also the rear folding headrests) Had to check for myself because ford's website says not available for badlands. But the section of wire harness for this feature if there on our 2024 badlands. Will be ordering with ford points.
Ford Bronco Sport What did you do TO your Bronco Sport today? Screenshot_20250205_121032_Chrom
Ford Bronco Sport What did you do TO your Bronco Sport today? Screenshot_20250205_121134_Chrom
Ford Bronco Sport What did you do TO your Bronco Sport today? 20250217_121200
