Tow Hook
Any limitations on using the factory tow package with a tow eye in the 2" receiver?
Ford Bronco Sport Tow Hook 57255_W3[1]
It depends. There are towing limitations listed in your owner's manual. I'm not aware of any published limitations on using the hitch for recovery operations, but keep in mind this is not a body-on-frame vehicle, it's a unibody frame. The hitch is bolted to the unibody, but I think you could yank on it hard enough to bend things that aren't supposed to bend. Like I said: it depends.
davidg4781
I don't have the tow package so I didn't pay too much attention to this part in the owner's manual.
I will say Ford sells a part like this. The rear tow eye hole is also covered on factory installed tow hitches.
If you have front tow hooks, I would definitely use that before this, if possible.
Greeno
Buffalo, NY
patmat2350
Patrick
Temecula, CA
BS Heritage Ltd
FWIW: I have a Heritage Limited, which is supposed to be basically a Badlands with the Heritage color scheme...2L, suspension, etc. And the Badlands (and not other models) has the provision for the screw-in hook behind that little cover in the rear bumper fascia.
Guess what: They did NOT include that provision in the Heritage Ltd! So I'm screwed...or not screwed, since there's no place to screw it!
Wolf256
Jane
Kingston, WA
2023 Bronco Sport Atlas Blue
Should still be the same bumper. The access should be a pop out piece of black plastic just above the right red reflector/light. If you zoom my picture you can just make it out. Mine does me no good since I have the factory tow package that covers/blocks the underside of it, but I located when I had a 2022 without the tow package.
Ford Bronco Sport Tow Hook IMG_0135
patmat2350
Patrick
Temecula, CA
BS Heritage Ltd
Pop open the little cover, and nuthin but blank steel. Is this part of the factory hitch?
Ford Bronco Sport Tow Hook PXL_20241217_011718868~2
