Sync 3.4 Build 22251 Default Issue
I dont belive i downloaded all three....oh well screwed now.
If you actually did not download the License File you are correct you cannot go back to the Ford website and download Nav 2 22 again.
You can look around your Computer to see if you can find that License file and if you find it just copy from your Computer to the USB Drive SyncMyRide folder.
If you cannot find the License file, my suggestion is to call Fords SYNC3 Connected Services Team:
+1 (833) 389-0848
That number is for lots of things not just Sync and Nav but ask to get a Case # created because you were unable to download the License file. Then ask to be connected to an Escalation Specialist. This guy was super helpful to me for Nav 2 20 when Ford had a defect in the 2 20 download:
Daniel
IVT Research Escalation Specialist
Ford CX Team
1-866-631-3788 ext.76377
He was able to get management approval to have the Nav USB Device mailed to me at no cost to me. It actually took Ford’s vendor 3 times to fix the defect, twice they mailed me identical USB contents so now I have 3 USB Devices from Ford. I diagnosed exactly what the defect was, told Danial that and he got the vendor to fix the defect and the 3rd USB Device I was sent worked.
Good luck!
PugDad
Bronco Lilly
Newfoundland,Canada
BSBL
Thank you for all the info.
I will try, if it doesn't pan out i will just have to purchase the USB.
rocks
SC
I bought the Ford USB. I downloaded the 23188 easily but always had a problem with the map update in a '19 Ranger I owned.
PugDad
Bronco Lilly
Newfoundland,Canada
BSBL
I bought the Ford USB. I downloaded the 23188 easily but always had a problem with the map update in my '19 Ranger.
Could it be they want us to buy the USB? :piggybank:
rocks
SC
PugDad
Bronco Lilly
Newfoundland,Canada
BSBL
+1 (833) 389-0848
Daniel
Ford CX Team
Good luck!
I am dealing with the Canadian Ford team, your info is the US side, but agin thanks for the start in the right direction.
PugDad
Bronco Lilly
Newfoundland,Canada
BSBL
PugDad
Bronco Lilly
Newfoundland,Canada
BSBL
+1 (833) 389-0848
Daniel
Ford CX Team
Good luck!
I have the License file now, and will try to install later today. many thanks for your help. Great customer service on Ford's end, as well.
That was super quick!! That Ford customer service # has always been super helpful to me in the US.
PugDad
Bronco Lilly
Newfoundland,Canada
BSBL
Canadians are fast. Trying to stay ahead of our American neighbours.;)
The Ford Canada customer service is great as well.
JaxPony
Jax
Norfolk
2020 Ford Escape Hybrid Titanium, 2020 Bronco SPor
I kept getting a PKG_ERR03. Somehow my install got corrupted and it was the USB from Ford for the NAV 2 22. I also got escalated to a Ford Technology Center Specialist. They are refunding my cost for the subscription(without losing the 5 years), sent me a recovery file to download (will completely remove my Nav, GraceNotes, Voice (wasn't working anyway)..System stated Maps were updated but no voice commands or grace note update. They were very helpful as well. Will not use recovery file until I have the new USB Stick
Make sure you are on Sync 3.4.23188 or later before installing Nav 2 22. Will make the Nav install much smoother
JaxPony
Jax
Norfolk
I am according to my About Sync . I did the download on 9/2. Can I reinstall again to be certain. I did get another pop up stating it was updated to 3.4.23188 and I did it via USB which I thought was odd. I think I accidentally turned wifi updates on
Can’t hurt. But if it says you are on 23188 then you’re good to go.
