- First Name
- Jordan
- Joined
- Jul 17, 2023
- Threads
- 1
- Messages
- 1
- Reaction score
- 3
- Location
- Abilene TX
- Vehicle(s)
- Bronco Sport
For about a month or so, I noticed a vibrating sound coming from the back of my car. (I have an OB '21). When I took it to Ford (for an oil change but also another issue, will explain at the end) they told me it was fine. My car was at Ford for 2 weeks with a different issue along with the odd noise. When I went to pick it up I asked them if they discovered what was making the noise (as it had gotten louder), they said they test drove it and there were no issues. I took the car home and for 48 hours, it sounded like the my car was going to fall apart. The back of my car would make these grinding/skipping noises every time I turned my wheel in drive or reverse. We called back into Ford and they said to come back. I had 2 technicians get into my car when I drove and they immediately said it was the rear differential. We drove it around the parking lot and took turns, they even got under my car as the other drove. They said the back of the car would shake as the rear differential turned. They told me that the car was not drivable/safe and took it in. After they did their investigation, they discovered that a gear has broke causing grinding to happen when it turned. Metal shards were all in the rear differential, even after flushing it out. Ford gave them the OK to replace the entire rear diff as it was too damaged to save. My car was at Ford for another 2.5 weeks waiting on the part and to install. I got my car back and it sounds great.
My car was previously at Ford because it had over heated. I checked under my hood after it had over heated and noticed all the coolant was gone. Thought this was odd considering this was a fairly new car and I have never had to fill it up yet. We re-filled it and after driving it again, the coolant was gone. I took it to Ford the next morning and said my engine was eating my coolant. (There were no leaks falling onto the ground or outside of the chamber that we could fine). Ford had my car for 2 weeks and said they couldn't find any leaks and were waiting on a call from Ford to OK the release. After Ford contacted them, they would a small leak in my water pump that was causing the leak. So they had to order a new water pump for my car. Since then, I have had no issues.
Crazy to say that I had 2 major repairs done to my car in the same month, thank goodness it was all covered under my extended warranty. I have about 48k miles on my Bronco sport.
