Pretty good MPG with the Badlands!
BravoAlpha
Oklahoma
I haven’t reset the mpg since I drove it off the lot.
mix driving
250 miles of turnpike (80-90 mph) rest is city, dirt roads, and rural highways (55-65mph)
87 octane, 784 on odometer, 24.7 mpg avg
im pretty damn content with that
Jess1
SE Texas
F150
Only 460 miles in first month, so still breaking in. FWIW, station pumps aren't tenth % accurate, so...
mix driving
I’m getting about the same as well. I’m happy with it too.
...the biggest gain in MPG at higher altitudes occurs because the less dense air must be countered with less fuel in order to obtain the proper stoichiometric ratio.
True for a normally aspirated engine; not as much for a turbocharged engine.
thekingprawn
Dustin
Kingston, Wa
I routinely get about 31 in my Sentra, guess I'll have to budget it a little different when my BSBL comes in.
Ugh I was all excited for some highway driving today....but 35+ mph headwind killed the mpg today only got about 24
She was a bit breezy yesterday wasn’t it. Got to watch the hood flutter every once in a while.
baja_bob
Bob
michigan
21 Bronco Sport
My Big Bend has 33,600 miles mostly highway, I can average 30-32 mpg during summer months. Using winter blend gas it goes down to about 28 mpg, even with the BFG K02s (stock size) this spring I've seen it come back up to 30 mpg with Eco mode and cruise control sometimes.
This is at 980 ft. above sea level with 89 octane gas.
DMEARC
2019 Mustang, 2021 BS OB
This. When people mention that manual fuel calculations are more accurate they fail to take into consideration that the pump itself has a tolerance that it works within. Then some pumps are more sensitive to others in regards to the auto shutoff feature.
Jess1
SE Texas
F150
Indeed. The general accepted error is roughly one cup liquid for every 5 gallons... so at a pint and a half every tank, makes accurate data pretty much impossible.
The more I think about this the less it makes sense. I've been flying piston-powered aircraft for several decades, so I'm very much aware of the effect of altitude on engine operation. You are correct that the computer leans the mixture due to less dense air (we do this manually with a mixture control for aircraft engines), but this doesn't make the engine more efficient, it just reduces power output, and when you make less power you use less fuel. Unless there is some mechanism I'm unaware of, engines do not become more efficient at altitude, they simply make less power because there is less oxygen to burn. This is most apparent during acceleration. Maximum acceleration requires maximum power, and most acceleration testing is corrected to sea level, because that's where the engine will produce the most power.
There are only two ways (I can think of) to improve fuel economy: Make the engine burn fuel more efficiently so that you get the same power on less fuel, or reduce the amount of power required to travel at the same speed. All other things being equal (wind, air density, temperature, grade, tire rolling resistance, etc.), it requires a given amount of horsepower to maintain a given speed. I climb higher when conditions (winds, clouds, etc.) permit not because the engine operates more efficiently at altitude, but because the lower-density air reduces drag, which means I can maintain the same speed using less power--and fuel.
AmazingSieve
Denver
Bronco Sport Badlands
I got you beat lol. On the way up to the Sierras I got…..
18.6
DMEARC
Great. I’m familiar as well. So you understand what happens when you climb to 10,000 ft without leaning: you’ll lose power as you climb. And when you start leaning: you’ll gain some power back. So you’re gaining back some power and burning less fuel by leaning the mixture to accommodate the less dense air.
Do you know what altitude Cessna says the late model Skyhawks can be leaned at? It’s a lot lower than most pilots think.
