- First Name
- Mark
- Joined
- Oct 30, 2021
- Threads
- 119
- Messages
- 6,733
- Reaction score
- 13,152
- Location
- St. Jacob, IL
- Vehicle(s)
- 2021 Badlands | 2020 Escape
Yes, you've explained how to correct the mixture for altitude. You haven't explained how the engine can be more efficient at altitude. You're burning less fuel because you're making less power, not because the engine is more efficient. Climbing to altitude is really no different than closing the throttle. You have to reduce the amount of fuel injected into the engine as you close the throttle to keep the mixture correct. If you don't, the mixture gets too rich and you lose power, the same way it gets too rich as you climb.And when you start leaning: you’ll gain some power back. So you’re gaining back some power and burning less fuel by leaning the mixture to accommodate the less dense air.
If you have the proper instrumentation you can lean the engine at any altitude.Do you know what altitude Cessna says the late model Skyhawks can be leaned at? It’s a lot lower than most pilots think.
