- First Name
- Sherman
- Joined
- Dec 1, 2021
- Threads
- 32
- Messages
- 1,916
- Reaction score
- 2,058
- Location
- MIDDLETOWN, MD
- Vehicle(s)
- '22 Badlands ordered 12/17/2021 - Arrived 3/25/22
Just curious, where does the 80-85% come from? I've never heard that before.A few key things here that I think need clarifying.
1. You say you have the Heritage Limited but your profile says a 2022 bronco sport. the Heritage packages were introduced with the 2023 models. You also mention having the tow package. Was that factory or did you install a third party tow package? For all models, a third party hitch is limited to only 1500lbs. If you do have the 2023 Heritage Limited with the factory tow package, then 2200lbs is your limit. It seems like that's what you have but double checking.
2. How did you weigh your trailer? Was it just some random scale at a truck stop or did you have it weighed by someone that knows what they are doing? The dry weight plus a full water tank is going to weigh over 1750.
What else do you have on it? Assuming #1 is true you shouldn't be putting more than 80-85% of the capacity. which in this case would be 1760-1870lbs. That's basically the dry weight plus water, so adding anything else to it is inside that grey area between 80-85%, which is likely why you're seeing the results you're seeing. You're tapped out, or possibly a bit over. I would first recommend getting it weighed again from somewhere else and see if they pull the same as your first weighing.
Lastly, even if you're in the 80-85% range, you are pulling a significantly heavy load and it will impact the vehicles driving substantially. If you're within the recommended weight then you should be safe and not dealing with overheating like you are. Check to make sure your coolant system is all in good working order. The tow package should have come with an auxiliary cooler. it's possible this wasn't installed for some reason.
