Front brake job
Methodical9
Jason
Alberta
2025 Ford Bronco Sport
Hello, i have to change the front brakes on my 2025 bronco sport 1.5l and i just wanted to make sure that the brake maintenance mode is only needed when working on the rear brakes?
Thanks
jlpskydive
J.
Satellite Beach, Fl.
25 Badlands, Sasquatch, Oxford White
I would assume so for the emergency break function, but not sure. Can you get to that mode without FORSCAN?
jlpskydive
J.
That’s awesome, I learned something today, on my wife‘s Pathfinder is used a 9 volt battery……. No… I’m not proud about it, but it worked.
Methodical9
Jason
Alberta
No idea, maybe mine just came with shit pads. It came with shit continental tires so why not lol. They are deffinately almost gone
Methodical9
Jason
Alberta
maintenance mode is only for the rear. and i forgot about it when i changed my rotors and pads with no ill affects. but maybe because i also changed my brake fuild at the same time.
Thanks
Scapino
Concord, NH
2021 Ford Bronco
I've changed my rear pads without using Maintenance Mode and had no problems. You can also disconnect the battery if you want to avoid the Maintenance Mode aspect.
NOTE: I put my '21 Bronco Sport in maintenance mode once and couldn't get it to revert back to normal mode. I had to take it to Ford to get it out of maintenance mode. So, proceed with caution...
Ernest T
Dennis
Central Texas
I think it depends on your typical driving environment. We live in a rural area and I’ve put well over 100k on all our vehicles without changing pads. In fact, I don’t think I’ve changed pads on a vehicle since 2010 when I changed the pads on our 1997 F150 at 140k. Both our other vehicles have over 100k and still have lots of pad wear left. I’m having the brakes inspected and the brake fluid changed on the Cherokee next month so I’ll see how the look.
