- First Name
- Russ
- Joined
- Jul 24, 2023
- Threads
- 0
- Messages
- 12
- Reaction score
- 12
- Location
- Milton, NH
- Vehicle(s)
- 2021 Bronco Sport
We'll see what they figure out or don't, seeing as how the AutoStart is almost government mandated they may not want you to know it causes issues with battery life.
I don't know for sure but I suspect that just like the new so called smart chargers, that once battery voltage goes below a certain level the computer shuts off charging and at some point the engine quits because there is not enough voltage for the electronics. Charging a shorted or damaged battery could cause an electrical fire which could would be significantly worse than engine shutdown and the computer likely use battery voltage to look for that.
My opinion is the autostart at the very least great shortens battery lifespan. Battery life is really measured in discharge/charge cycles not time so each time the starter discharges the the battery which then requires recharging is going to eat into battery life and in areas with a lot of stop and go traffic I'm betting significantly so. AGM batteries will hold up better but the underling issue is still there.
So for me the Autostart is turned off as so as I think about it.
