Cup Holder Ambient Lighting
Art4All
Indiana
'22 Bronco Sport Outer Banks - Cyber Orange
When was your Outer Banks built? Mine was built in January and has the wiring in it for the lit cup holder. Another member on here has one that was built in February or March and theirs doesn’t have the wiring. Did you check for the wiring before ordering the cup holder?
Yes, I suggest you take the old cupholder out to assure you have the wiring. My BS Outerbanks was built in February and does not have the wiring. I'm glad I checked before I ordered. There was another member on here that had the same issue. Best of luck.
MMR_A51OBX
Matt
Illinois
It was build 12/21. I think I should be good. It has a ten day return window, but I can check the console later today. Thanks!
Art4All
Indiana
Yep, sounds like you should be good. Best of luck :)
Medic10812p
Andy
Arkansas
I have the lighted cup holder, part number Ford LJ6Z-7813562-FA. I found one and my 2022 Badlands is not wired for it. I will take $40.00 shipped to lower 48. I paid $48.76 on eBay Message me here
Feint
Jon
Chicago
2022 Badlands
You should try to wire it up yourself. There's power to that area. Just splice in.
Jenbeth
Jen
Crestwood, KY
Driving the Husband’s F-150
Tools Required:
-Pry Tool
-T25 Torx w/ratchet
First you will go inside your vehicle and locate the shifter dial/cup holder area.
Ford Bronco Sport Cup Holder Ambient Lighting 7EDFD8EF-422B-4621-8932-95DAB7927B34
Then you will pry it out from the front first as there are tabs in the back that lock it in place.
Ford Bronco Sport Cup Holder Ambient Lighting 9BDCFCB2-8B77-4ABE-9D32-E4AA9EFA1114
Ford Bronco Sport Cup Holder Ambient Lighting 5ED91C4F-5FD7-4E8A-974E-85412AAAE0E4
After removal of trim, flip it around on a side (optional to disconnect every connector if you want more wiggle room). I didn’t disconnect any other connector besides the pre-wired cup holder connector.
Ford Bronco Sport Cup Holder Ambient Lighting 024D6758-8144-4DAC-834B-AF56D14BDF62
Once that is disconnected you can go ahead and remove the 3 T25 Torx screws holding the cup holder in place. Once removed just wiggle it off and remove it then install the new ambient lighting cup holder in its place and reconnect connector and snap it back and place and enjoy!
Ford Bronco Sport Cup Holder Ambient Lighting BD052064-3D58-4F4E-8094-669F801944DB
Ford Bronco Sport Cup Holder Ambient Lighting F657D6BE-9D04-4AB5-B6A9-2A1F78E7E11F
Ford Bronco Sport Cup Holder Ambient Lighting A45459F2-F023-4196-B227-A101492584F7
I have a 2022 OBX and there is no connector inside, pic below. Any suggestions?
Ford Bronco Sport Cup Holder Ambient Lighting C850C55E-C76F-4B9C-8E95-B129D78091B8
Jenbeth
Jen
Crestwood, KY
How do you recommend doing that?
Escp2BroncoS
2022 Bronco Sport Outer Banks
Great info! I don't know if our '22 OB has the wiring but I would really like to have the illuminated cup holder. I have the trim tools and I've removed interior panels many times, but I'm uncertain as to where to insert a pry tool to pop the front of the panel off. There doesn't seem to be enough space to insert a tool and obtain leverage. Can someone please provide a little more detail or pictures on this process?
JCampos30
JCampos30
Juan
Laredo, TX
22 Bronco Sport, 20 Ford F-150, 14 Mustang GT
Try using a volt meter and get a readout for a wire that gets power when your lights are on or if you want to get technical I’m pretty sure you could tap into the footwell lighting.
JCampos30
JCampos30
Juan
Laredo, TX
Just try lifting it a bit from the top. The area that goes to the usb ports and it pops off fairly easy.
Jenbeth
Jen
Crestwood, KY
I’m concerned about voiding the warranty on the electrical components, so I think I’m going to either return or sell the ambient cup holder I purchased. I could check with the dealership to have them install which might help with the warranty issue, but not sure it would be worth the cost.
Jenbeth
Jen
Crestwood, KY
I have the part, but not the plug on my 2022 OBX built on 7/4. DM me if you are interested in the part. Paid $34.18, just add shipping to your neck of the woods and it’s yours.
Ford Guy
Trent
Raleigh, NC
2005 Ford F-150 XLT, 2022 Ford Bronco Sport Outer
If you look at the bottom of your cup holders, if there is a wiring harness plugged into the circled location in the picture, that's the wiring you need. It unplugs from there and plugs into the ambient lit cupholders.
Ford Bronco Sport Cup Holder Ambient Lighting 7857706D-4DF7-4FCF-BA18-05AD3BF5FDD3_1_201_a
Just want to ask a quick question. So if I understand everything there is a wire and harness in the console once the shifter cover is removed that the new cup holder will hook into?
M3H7363
2023 Maverick hybrid XLT
Yes and no. Depends on when it was built. Mine was built in January and had the wiring. Another member has one that was built in February and didn't have the wiring. If yours is a recent build, you probably don't have it. I checked mine before I ordered the new cup holder.
Ford Guy
Trent
Raleigh, NC
Understood. Thanks for the quick reply.
