BL Sasquatch AUX Switches Wiring Guide?
ELCouz
Canuckistan
I took my BS BL Sasquatch to my Ford Dealer and let the tech run the wires. Then I hooked them to a terminal block and attached my Diode Dynamics amber fog lights and for future options.
Ford Bronco Sport BL Sasquatch AUX Switches Wiring Guide? Diode Dynamics pods and bar
The dealer could have put more pride in hiding the wiresđź«
What did the dealer charge for that?
pixlpush
Sean
Portland, OR
Tern GSD Ebike (car free at the moment)
It's pretty much where the Ford diagram shows but I fished out the Green & brown "B" Aux 2 wire today. It was around the backside of the wire bundle not the easiest to find. you could feel the single wire through the electrical tape. Here's some photo's of where it was on mine. I plan on using it for some front floods mounted to the Sasquatch bar. Just waiting on mounting brackets
I found it taped up with shiny electical tape right where the red arrow is -->
Ford Bronco Sport BL Sasquatch AUX Switches Wiring Guide? IMG_1773-EDIT
a bit closer view -->
Ford Bronco Sport BL Sasquatch AUX Switches Wiring Guide? IMG_1772-EDIT
closeup of the wire itself, green with a brown stripe and capped off. It sure would have been nice it the put some sort of label on these.
Ford Bronco Sport BL Sasquatch AUX Switches Wiring Guide? IMG_1775-EDIT
pixlpush
Sean
Portland, OR
I just realized that “BJB” means battery Junction box. Still not super helpful. Something about digging into the electrical tape wrapped around part of the main wiring harness where you "think" the wire you’re looking for might be is a bit unsettling.
I just realized that “BJB” means battery Junction box. Still not super helpful. Something about digging into the electrical tape wrapped around part of the main wiring harness where you think the wire you’re looking for might be is a bit unsettling.
Yep - someone before you did the same and posted a pic like you did - believe is at the link I posted above (somewhere either before or after the point I linked to). I’m guessing you hadn’t seen the prior posts on same topic.
pixlpush
Sean
Portland, OR
The brackets arrived and I added some cheap Harbor Freight 3" LED floods to the AUX 2 switch of my 2025 Sasquatch. I mounted them to the front bar. They sit forward of the bar, they’ll probably get hit at some point— So $85 felt better than some of the much more expensive options for now.
They’re actually brighter than I expected and only draw 50 watts each, so the 10-amp AUX 2 circuit was plenty without needing an extra relay. I routed the wiring through the existing holes in the steel bumper where the recovery points and bar pass through, which worked out nicely.
The brackets are from Amazon and are surprisingly well made. They should work with other lights too if I decide to swap them later. A quick P-Touch label on the switch and I still need to aim them but overall I’m happy with them for now.
Harbor Freight 3 in. Roadshock lights
Vazeswin aluminum mounting brackets
They won't interfere with the front plate once I get it and don't block any of the cooling
Ford Bronco Sport BL Sasquatch AUX Switches Wiring Guide? IMG_1788
The Brackets just wrap around the bar and are quite solid once tightened up
Ford Bronco Sport BL Sasquatch AUX Switches Wiring Guide? IMG_1789
Wires fed throught bumper holes and up into the engine compartment pretty easily
Ford Bronco Sport BL Sasquatch AUX Switches Wiring Guide? IMG_1790
P-Touch label looks ok too.
Ford Bronco Sport BL Sasquatch AUX Switches Wiring Guide? IMG_1787
