Hard to say but if the instrument cluster being bad perhaps was drawing way too much current and just drained the battery. Could have even drained the battery with the vehicle off.…Conclusion, turned out to be a defective instrument cluster.
I have had no electrical issues since.
Now, with this recall, I'm wondering if the original problem I had could have been a result of insufficient alternator charge to the battery. The instrument cluster created the issue. The battery, being good, trying to do its job, wasn't getting the juice necessary to start the car.
Service guy was incorrect on the radio presets.Had this recall done at the dealer this week on my '24 BS OBX. Don't notice any difference in anything. The service guy said I would have to reset all my radio stations and the trans would be a little off while it relearned my driving habits. Well, none of that happened. A couple of days later I called the service manager and told him that nothing had changed. He said that's normal and maybe his guy was just joking with me. Hmmmmm.... So what happened when you had it done?
Same here.Service guy was incorrect on the radio presets.
Give the vehicle some driving time and the transmission should go through a relearn cycle (mine did within a few days to a week after 24S24 was done)
after
I would hazard a guess that most manufacturers' definition of this term differs markedly from most consumers......acceptable failure rate...
WTF?guy was just joking
Step 1 of the Technical Service Instructions for this recall says:I drive my 23 BL daily, so should be sufficiantly charged. The mobil tech said my battery tested a little low and placed a charger on it before the updates.
Good article, it’s my experience with vehicle batteries. Very common for voltage to appear fine for example with the engine off under auto start/stop, then suddenly degrade to the point the vehicle won’t start.1) What would cause a "sudden" change (decrease) in SOC and/or sudden 'degradation' -- to the point that accessories fail to operate and/or the vehicle stalls?
Had the recall done on my 21 BL lost 4mpg but, charging now at 13.8 not 14.9.For those of you that already had Recall 24S24 completed on your vehicle, you may want to call your dealership and find out if you need to be reverted back.
At least one dealership stated ”Ford is having issues with the cars after this update”.
EDIT: 5/24/2024 update, “My dealer said as of today (May 24 2024) the program has been resumed.” … contact your dealership for up-to-date information.
Reminder, this is what Recall 24S24 applies to:
Recall 24S24 is for the BCM/PCM Calibrations:
NHTSA Part 573 Safety Recall Report 24V-267
Date: APR 12, 2024
Ford Recall #: 24S24
Affects: 2021-2024 Ford Bronco Sport built through March 13, 2024
Number of vehicles potentially involved: 456,565
Estimated percentage with defect: 100%
Also affects 2021-2023 Maverick
Description of Defect: An insufficient calibration strategy for detecting sudden battery degradations during a drive cycle can lead to (a) a vehicle that is unable to restart after an auto start/stop event or (b) experience a stall while coming to a stop at low speed. Either may be accompanied by a loss of 12-volt accessories, including hazard lights.
Owner notification letters to be mailed after May 13, 2024.
Additional information here.
https://static.nhtsa.gov/odi/rcl/2024/RCLRPT-24V267-6161.PDF
2024-05-20 Update:
https://static.nhtsa.gov/odi/rcl/2024/RCMN-24V267-9251.pdf
possibly similar for me … how many weeks has it been since Recall 24S24 and the loss of 4mpg?Had the recall done on my 21 BL lost 4mpg but, charging now at 13.8 not 14.9.
About 3 weeks. I installed a volt meter after reading all the battery change outs. The system was overcharging. I'm over 3 years on the orig. battery. Do not drive it much maybe in a few more weeks it'll be back up to the 29mpg that I've always had. At the beginning, if gentle, I would get as high as 31mpg. My overall mpg is fluttering around 29mpg.possibly similar for me … how many weeks has it been since Recall 24S24 and the loss of 4mpg?
