Mustang Mach E Conversion
Amazing! So 17" wheels definitely won't fit then?
Haven’t had the time to check yet. But I’m going to go with my gut and say no. Lol
VinnyLongPour
Vincent
Long Island
Ford Bronco Sport Mustang Mach E Conversion IMG_6709
Those decals aren’t going anywhere ever. 😝
those look amazing for sure - kudos. the decals are really a phenomenal touch, and matching the Badlands badge is brilliant. great idea for an accent color overall. maybe match your tow hooks too to further unify the look?
My tow hooks and rear shackle are red. I’ve debated painting them the same color… but the fronts have covers on them. Not 100% sure if I’m dedicated to painting them permanently or not 🤣
thadt
Thadz
Tx
2021 Bronco Sport Outer Banks
Hello everyone, and thanks for letting me in into this community!
Regarding the swap of the front brakes; is it a straightforward change of taking out the old ones, and putting in the new Mach e brakes, or is there a complete change needed to put those brakes into the bronco Sport?
I´m curious as my Bronco Sport OB already has factory 18 in wheels installed, and if it is just a swap, it would be a matter of purchasing the calipers and discs, bolting them and connecting the brake lines.
Thanks!
Cursed Bronco
Dakota
Indianapolis, IN
Thanks!
Based on the Maverick Forums, it requires slight modification and the drilling of a hole
Javier
Miami, FL
Ford Bronco Sport Mustang Mach E Conversion IMG_6714
Ford Bronco Sport Mustang Mach E Conversion IMG_6710
All done. Primed. Painted. Decals applied. Clear coated.
These look AWESOME! If you can, try to see if the 17" wheels clear the calipers. If this can be pulled off without changing the wheels, I am going to follow your lead on this.
thadt
Thadz
Tx
Thank you for the reply and pointing me to the right direction!
Just read, and realise there are different calipers, so on the look out to find ones that would fit with the 18" rims
I’m going to try… not sure when I’ll have time to get to it… but I will try. Going to wrap the calipers with painters tape before I do it, so they don’t get scratched up IF they rub.
Ford Bronco Sport Mustang Mach E Conversion IMG_7038
Ford Bronco Sport Mustang Mach E Conversion IMG_7040
18s are the smallest wheel that’ll fit. 100% certain that 17s will not fit. Found a fusion wheel in 18” and it fit.
And yes, I’m aware it’s upside down… I just grabbed one to test fit.
Wheels and tires are ordered.
Going with Ford Bronco 18x7 wheels, and Toyo Open Country AT III in 245/60/18.
Ford Bronco Sport Mustang Mach E Conversion IMG_7139
Saw a dude post in the Maverick group on FB running 18s… makes the calipers look absolutely chunky.
Ford Bronco Sport Mustang Mach E Conversion IMG_7259
Also just learned, there is this option out there, from a Volvo S60R (2004-2007 body style) that uses the factory rotors and just needs a minimal amount of trimming the mounting surface approx .1”
They need new lines to mount from the chassis hard line to the caliper. Which is about $125.
I may order these and just compare and see what I think. It does have me wondering though… that same Volvo also has Brembo calipers in the rear… it would be complicated with the electronic parking brake, but anything is doable with enough time and brain power.
Ford Bronco Sport Mustang Mach E Conversion IMG_7265
This is very cool. Is there a rear Brembo style option possible for the platform?
Not sure. I’m going to assume no, because of the electronic parking brake feature. But as stated in my post right before yours, there is a set of rear brembo calipers from an 04-07 S60R that MAY fit the knuckle. If they do, it would then be figuring out how to make the electronic parking brake work with it.
