Tire Pressure
Tlcmommy
Tricia
Kentucky
Bronco
Does anyone know what the tire pressure is suppose to be at ? Mine has 40psi in each tire from the factory
thekingprawn
Dustin
Kingston, Wa
Which tires? It should be printed on the sidewall. Also the vehicle data plate on the B pillar or driver's door edge should have info, but that is only applicable to the stock tires.
Ford Bronco Sport Tire Pressure EDUread-sidewall_maximum-capacity-inflation-pressure-markings
tburner
Troy
DFW, TX
Factory tires should be at 33 psi. Most aftermarket tires should be pretty close to that, too. Don't inflate your tires to the pressure on the tire sidewall. That's max pressure and the majority of drivers will never need that much pressure in their tires.
Deleted member 6350
According to the Manufacturer it’s on the drivers side when you open your door. 33 Pounds.
Ford Bronco Sport Tire Pressure 21313608-5040-4CD5-9A3B-B1BEA3C5A8CD
33. They ship them higher to keep them from flat spotting.
SWUKU
GB
KY
Mine came-in at 40 too.
I released the pressure down to 33, but the dealer put them back at 40 when rotating the tires.
Twice.
BravoAlpha
Oklahoma
Good info. Mine are at 46 & 48 psi
Jess1
SE Texas
F150
Yikes. 40+ would impact the ride quality... and not in a good way.
Reactions: Jrl
Unfortunately most dealers aren't adjusting after delivery from stories I see here and my own experiences. I typically run 33s all around in warmer months and 35-36 in winter. My daughter's car has nitrogen (33) year round as the N tends to stay more stable.
Bdud
Brian
Chicago
Ford Bronco Sport Tire Pressure Screenshot_20220410-192205
Oh wow. I would have thought the dealership would know what pressure to put in the tires.
Drop them down to what is says on the doors when they are cold. They are shipped high to keep from flat spotting. I’m running 33 on all 4 corners.
Jmuns
2022 Bronco Sport BL
For those with 245s what are you running them at?
BravoAlpha
Oklahoma
I just did. I’m glad I read this thread. I wasn’t even paying attention.
