Water inside by tailgate after car wash
warrior
scott
21 bronco sport
just went through a touchless car was and there is water inside rear compartment. Has else had that issue. First edition with less than 5000 miles
VirtualJMills
Jason
California, US
ROADTRIP
Brandi
Just noticed this after going through the car wash. Noticed the headliner was wet with blue streaks. Noticed that the rear top light was sticking out and the pins underneath that hold the black flap were out. The line for the wiper fluid that looks like a stopper is attached to the body was out. So I taped that down with electrical tape. I went to the dealership and asked about the light and the service department did not know how to handle it so it is fun having a new vehicle that no one knows how to fix.
Ford Bronco Sport Water inside by tailgate after car wash 20211101_132216
Ford Bronco Sport Water inside by tailgate after car wash 20211101_132612
Ford Bronco Sport Water inside by tailgate after car wash 20211101_132752
Ford Bronco Sport Water inside by tailgate after car wash 20211101_133107
ChefDank
Nick
New York
I'm going to check mine
Hi there, Brandi! This definitely doesn’t sound like the experience we want you to be having– If you'd like to, go ahead and send a message to us with your VIN and approximate mileage. I’d be happy to look into this for you. Thanks!
ths0002
Tennessee
I've been having the same issue. We took it to the dealership 3 times to fix it and they haven't yet. It's not their fault, the vehicle is new, and they are trying to figure it out, too, but it is definitely something with the window and the seal.
SM05
West Virginia
Man The Ham
Phillip
Washington
Just had this same problem today. Just got out of the car wash and I heard water sloshing around for a bit. When I got home, I opened the trunk door and I found that water is somehow getting through the rear window. I dried everything inside and then I grabbed the hose with low spray to see if it was just the car wash having too much pressure. When I opened the trunk there was water again, getting through rear window seams. Back to the dealership....again. smh
Ford Bronco Sport Water inside by tailgate after car wash Screenshot_20211108-165932_Gallery
Ford Bronco Sport Water inside by tailgate after car wash Screenshot_20211108-170153_Gallery
Fergus
Fergus
Maryland
2021 BS OB
Those touch less car washes shoot high pressure water at angles that the seals in vehicles weren't desidesigned handle.
JerryC
Memphis TN
I'd be surprised to hear that Ford doesn't test their vehicles in all kinds of automated car washes. So many buyers do not wash their own cars.
I haven’t washed my Escape in years! ?. The dealer won’t even run it through the wash after an oil change due to the rusted out rear quarters.
Check to see if the seals are lubricated. Perhaps the Mexican desert dried them out if yours spent time on an extended vacation. A little silicone lubricant goes a long way.
JerryC
Memphis TN
I rejuvenated the nearly thirty old sunroof seals in my Bronco II that way. The seal soaked up an entire tube of silicone lubricant. I put it on the seal and the seal just kept absorbing it.
A cold weather tip I got from a mechanic is to use silicone spray on the door seals in the winter to keep them freezing shut. If some snow or water gets on the seals the silicone will keep it from sticking when it gets below freezing.
AWallace151
Andy
Chicago
Bronco
I’m getting the exact same thing happening to my BS. Have you been able to find a fix for it?
